I’d like you to explain the physics of transferring all of the weight off of the inside rear tire to the outside rear tire, just by locking the rear axle.
You know, just enough to get that piece of paper under the inside tire. Go for it. |
White and Nerdy
The weight transfer from turn in/cornering is doing that.
Two things. One you don’t transfer that much weight. Two, it has nothing to do with whether the axle is locked or not. So go ahead tell me how a locked axle transfers weight differently than a differential.
Torque (accompanies high revs) holds the car down.
Torque is a rotational force, with rear wheel drive this turns the wheelbase of the car into a lever arm, resulting in the front end being pushed down - increasing road holding handling. It's probably easier to test out the opposite, lift suddenly off the gas in a turn and the front end will lift - maybe scary and expensive - WARNING.
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect Last edited by kach22i; 05-25-2022 at 04:31 PM.. |
White and Nerdy
The purpose of lifting the inside rear is because of the locked axle without a diff rather than the other way around.
Front geometry is part of getting the inside rear lift but it also takes weight transfer to finish the job. |
You’re dodging my question. Why don’t you give us the formula for lateral weight transfer on an axle?
White and Nerdy
I've waited a little bit to type this, but when was the last time you had a mental evaluation javadog?
You say I'm dodging a question; but the question is about a position I never had. |
Questioning my mental health, that’s not nice.
I believe your position is that whether a drive axle has a differential or not affects the transfer of load on that axle in the corner. You seem to think that solid axle cars transfer a load differently. I’m telling you the differential has absolutely nothing to do with load transfer. So I’ve asked you to explain your position. Pretty simple. |
White and Nerdy
And... Quote:
Oh so repetitive…. You missed one.
Then tell me how the question of what differential type is there affects the load transfer. To save you some time, I will tell you that the lateral load transfer is dependent upon the lateral force being applied through the center of mass, the height of the center of mass above the ground and the wheel track distance. That simplifies it a little bit, as we are not differentiating between sprung and unsparing masses, but it will be sufficient for our discussion. Personally, I think you’re losing the plot here and it’s not load transfer that’s the issue. Differential types do have an affect on the handling but it’s not because they change the amount of load that is transferred. |
I don't think it's normal to design a car to lift the inside tire, front or rear, completely off the ground or even to where it's just kissing the ground. Granted, anti-roll bars do exactly that, lift the tire on the side opposite to the side being compressed with the purpose of increasing lateral load transfer on that axle. That action actually decreases the traction available on that axle.
IRS vs solid axle is something else entirely.
Air-cooled 911s will lift the inside front tire in a corner but that’s because the car design is fundamentally crap. State of the art suspension, circa late 1950s, coupled with a fairly stupid mass distribution… |
White and Nerdy
It's intentional in a lot of solid axle race formats on tracks with both left and right tight turns.
It removes the undesirable fight between the inside and outside wheel taking a different radius around the corner. It also results in accelerating or braking torque vectoring from the outside rear wheel. On longer radius turns the difference between the radius the left and right follows is significantly less while on tighter turns it is more pronounced. Navigating a set of narrow hairpin switchbacks in a solid axle vehicle with fat tires getting that "kiss" of the inside in almost no contact while feathering the throttle will reduce scrubbed friction and leave more grip for cornering. On the other hand in high speed long radius corners with a high powered vehicle having the inside rear floating is not going to be desirable as the heat of that power will be going into one tire. To understand better find a vehichle with a locked rear axle, doesn't have to be a car. Hold the steering to lock and corner at half a MPH. Do it again at the appropriate speed to get a good weight transfer going, feather on some throttle and do not skid the outside tires and the resulting corner radius will be tighter at full steering lock than when creeping it. Last edited by Tervuren; 05-25-2022 at 08:18 PM.. |
i am back in the gas (just a little) after turn in, depending on how much i let the rear "turn" the car. i wasnt quick enough back in the gas last time out and i managed a nice 360. first time spinning it. ![]() that long turn i do under hard acceleration and having to shift while turning made me nervous at first in my 930. clutch in to shift always felt stable. i was worried about weight shifting when i put in the clutch.
Banned
trail braking achieves two things, and why i teach trail braking as normal, not some special thing (yes, i am a driving instructor): 1. you can brake later. this is intuitive to having more speed, you carry more speed longer, and that means your faster. 2. trail brake to kill understeer. this allows you to turn in at faster speeds than a straight line breaker would. which means you have faster apex speed, and a faster slowest cornering speed. this leads to faster straight line speed to because you got off the corner faster. if you are in significant oversteer on entry, you held on too long. |
Kantry Member
This thread is an excellent example of how most of us learn from doing something rather than hearing an explanation we don't understand because of incomplete or imprecise language or an incomplete frame of reference.
Lighten up please gentlemen, you don't usually change a person's mind by attacking them. Best Les
Best Les My train of thought has been replaced by a bumper car. |
Gon fix it with me hammer
Btw i never said never trail brake. Were are debating why not to be in neutral and coast through 1 single fixed radius turn. We arent talking about racing and combination of turns. Or outbraking or taking alternative lines For 1 single fixed radius turn i see no trailbraking as the solution to get trough that turn as the fatest way. Trailbraking is for variable conditions. Workarounds to things that take the driving away from the ideal line on a single fixed radius turn.. to keep it together despite people driving around you. For combinationsnof turns increasing or decreasing radius turns. All hose things . Trailbraking is 1 thing in the bag of tricks. But we arent taling about racing or all the variables We are taling about neutral through 1 corner Quite frankly diacussig all the variables will never work in text cause its way too dynamic
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 Last edited by svandamme; 05-27-2022 at 04:46 AM.. |
(the shotguns)
Years back did an autocross school with the 911. Took one time around the circle portion of the course with the instructor explaining how to widen or tighten the diameter with the throttle to get a feel for it.
In a 911 for sure you need to be able to shift that weight back over the rear wheels and that's kinda tough if you aren't in gear.
***************************************** Well i had #6 adjusted perfectly but then just before i tightened it a butterfly in Zimbabwe farted and now i have to start all over again! I believe we all make mistakes but I will not validate your poor choices and/or perversions and subsidize the results your actions. |
2:45 mark..................in a turn keep the throttle steady to keep the car balanced...............
https://www.youtube.com/watch?v=rKf2fRImrYI Does not claim side to side balance nor front to back balance, rather vague........... but I like this video's tips on adjusting the drivers position. 3:20...........in a turn keep the car under-load either decelerating or accelerating to maintain balance..........don't coast.......
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect Last edited by kach22i; 05-28-2022 at 09:43 AM.. |
