Waxing Bicycle Chains
Hi everyone,
I just started waxing my bike chains; anyone else doing it? I watch the GCN network on YouTube and they talk quite a bit about chain waxing on there and I have watched a few other videos as well. Seems like many of the pro teams are doing it as well. This isn’t really new, but what is new is now the technology has made the wax better than the oils we used and are still using. I retired a week ago and decided that I could easily make time to do the initial work and the upkeep. By far the biggest hassle is cleaning the manufacturers oils and greases off of the new chains- they must be perfectly clean before waxing. I bought a good looking ultrasonic cleaner which is has an outer plastic shell; not so good looking now as the Acetone took a “liking” to it! Inner tub is stainless, so it still functions fine. Apparently you only do the deep cleaning once. I bought a $30 crockpot to melt the wax in. I chose the Silca super secret wax as it gets good reviews. Rutager
Rutager West 1977 911S Targa Chocolate Brown |
I’m using 4 chains; more on this later...
So first off, you put mineral spirits in the ultrasonic cleaner and run the chains through, then a run with degreaser, rinse the degreaser off with water and then do a final clean with Acetone. The first chain in the Acetone turned the liquid white- yup, I neglected to think that the plastic basket for holding small parts would get melted by the Acetone, oops! After all chain were clean, I heated up the wax in the crockpot and submerged chain one. You need to then let the wax cool just to the point of it starting to turn solid then you remove the chain and hang it to dry. If you pull the chain out hot, the wax will just run out of the inner parts of the chain, if you wait too long too pull it out, you have huge chucks of wax on your chain- no problem, heat it up again and do better. Seems like 148F is the sweet spot. I built a board with 4 nails in it to hang the chains on to cool.
Why 4 chains? I have always thought that if a person changed out their chain once a week and replaced it with a freshly cleaned one, maybe the gears would last a real long time. Now that I’m retired, I’m testing my theory.
I have two Campy chains and two KMC chains and quick links for them both. Besides less friction with a waxed chain, the benefit that got my attention was how clean your drivetrain stays. After a week of use and 130 miles, I have zero regrets; looking backing and seeing shiny silver gears and being able to touch your chain without getting your hands filthy is awesome. Rutager
I could see a good wax being good for the chains, possibly less likely to attract dust/dirt. Probably repel water, and lube the chain.
You are a dedicated biker to care for your bike chain like that....kudos to you.
I'm ashamed to say that I only just oil mine once a year....and I do about 20 miles per day.
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI |
What's the real advantage? Less dirt?
I use this and a lot of the local guys also swear by it. https://www.performancebike.com/squirt-long-lasting-wax-based-dry-bike-chain-lube-17oz-sq-dl-500/p1367995?v=404554 When I changed out my chain after Christmas, it was drowned in the purple de-greaser, from Autozone. I switched solution three time to make sure all grease is off. Personally, I think there are some on there still but who cares. After drying off, I applied Squirt lube and ran it through the gears for 1-2 min. wipe up excess, let dry and rode it. Reapplication of squirt every 7-8th ride is all its needed. Chain is super clean unlike oil which attract a ton of dirt. I like oil still if I was competing but a clean chain out weights a bit of lube and dirty chain. I can't tell the differences between them. as long as they are quiet, I am happy. |
weekend wOrrier
I wax my chain. Often!
![]() There. I said it. I got tired of greasy chains. I have a second hand dental ultrasonic cleaner, so I douse the chains in it (filled with kerosene), clean, repeat, spray with some carb cleaner to get off the oily kerosene, dab with a bounty quicker picker upper, and drop in the crock pot. I twirl the chain in the steaming wax, pull it out, dowse it in another bounty quicker picker upper, and reinstall. (I use quick links on most bikes- some of my campy stuff has that masterlink thingee). I started this about a year ago. Most of the bikes are now waxed. It doesn't take very long. For me- the beauty is a clean cassette, and if a chain drops, I I need to grab it to change a flat, no grease hands. Does it last as long as other methods? I dunno, (and I don't think it really does), but my cassettes are damn sexy. For most my riding- gravel- it's just a lot of dust and debri. Sure, I could triflow the heck out of the chain, or whatever ritual of the day, but, I'm in the wax phase. I got off a gravel ride the other day, and dumped the chain in the wax crock pot- didn't even clean it off. Life is good. Last edited by LEAKYSEALS951; 06-11-2023 at 05:10 PM.. |
From my basic research, the drivetrain has less friction, so you save a couple watts- not a huge deal for me or most of us I would guess. It stays very clean, which has the double benefits of reducing wear and because you don’t get the grime, you keep saving the watts. Once dirt gets in a normal oil, friction goes up making it slower; think valve lapping compound- oily grit being forced onto moving parts.
The hot waxing is slightly better than drip in because the drip in has carriers that evaporate leaving space in the chain rollers. The hot wax fills all the voids. One video I watched said that using the drip and then after it dries doing a second drip helps in filling up more voids. It seems that a lot of people will hot wax and then every couple hundred miles will use the drip and after a thousand miles will hot wax again.
weekend wOrrier
I'll tell you one thing, that ultrasonic cleaner can pull some darn stuff off the chain.
Each year our family goes to Hilton Head island, I ride up and down the beach every day. When I get home, I disassemble the bike, and the SAND that fills the base of the ultrasonic cleaner from the chain alone is huge. Also- I'm a wattage freak, but I'm not going to dissect wattage over a chain- what I will say, is that with a sharp clean drivetrain, you will FEEL SEXY and psychologically feel faster because of it. It is a mental bonus. It is like a clean car or garage. It will lift your spirits
Evil Genius
Spray on Chain Wax has been in the motocross industries for decades. dust free, doesn't fling off, and you sure don't have to get Mama mad cooking wax in the kitchen.
really, boil your own wax, that's just silly. https://www.amazon.com/Maxima-74908-Chain-Wax-Aerosol/dp/B00230IOJ4/ref=asc_df_B00230IOJ4/?tag=hyprod-20&linkCode=df0&hvadid=312190122371&hvpos=&hvnetw=g&hvrand=3895841395629504611&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9033391&hvtargid=pla-569122842891&th=1
Life is a big ocean to swim in. Wag more, bark less.
weekend wOrrier
I have this solved by having a box for the used chains and once all 4 are used, I’ll hot wax them, rinse and repeat- they might not end up being used in the same order, but will get used the same amount of times.
weekend wOrrier
What I "used" to do back in the day was hammer a finishing nail in the wall.
A nail small enough (narrower than a link pin) so chains would fit over it. The first chain was unused, it would mount flush against the wall-unstretched. It was never used. It was a control chain. It would dangle to a certain length. Subsequent chains were mounted outboard of it in order of useage, the longest chains being the most stretched. They were rotated, using the shortest chain (compared to the unused shortest chain) first. This worked well, until I moved, forgot the order, and 13 years later, I have my retirement savings tied up in jumbled campy chains in a drawer in my garage!!! Arghh!!! I will never retire now!!!! Last edited by LEAKYSEALS951; 06-11-2023 at 05:55 PM.. |
I must be really lazy compared to you guys. I remove chain, dip in whatever is available to remove oil, even gasoline. oil it and back it goes. For the past few years, I use that Squirt, done, back on the road. Once the chain starts to wear, depending how many miles I do over the year, it usually goes in the trash after winter followed by new chain installed. Its not worth confusing old chains and whatnot. My teeth are worth way more then the price of a chain.
The unknown, but talked about is how much less wear happens to the gears, I spent about $600 on a new cassette, chainrings and jockey wheels, so if I can extend their life it would be nice. My 4 chain experiment has to do with my understanding that the chain stretches and that is a big factor in the gears wearing out to match the chain gaps. I own the fancy chain checker and have tried replacing as needed, but I always have ended up with skipping on a new chain; I figure the whole mess will wear the same and together giving 4 times the life of one chain...
I use some sort of hexane solvent with wax stuff on my mountain bike. It’s killer.
And…way less effort. But, you get a ton of less friction. Nice! |
Wax is better because it doesn't attract dirt. I use a mixture of solid paraffin and lamp oil. I got some PTFE powder and add a bit if that. For cleaning I have a multi-step process:
1 - kerosene to get the old wax off 2 - citrus cleaner 3 - laundry soap and water 4 - alcohol to get the water out 5 - blow dry and put in the sun to get the remaining water out
Sold: 1989 3.2 coupe, 112k miles |
I've been waxing for a few years and won't go back.
Couple of tips-forget the ultrasonic, its really not needed. A couple baths in fresh oms in a mason jar or similar to clean factory stuff off is better. I "never" clean a chain after the initial prep-after 300 mi or so, I throw it in a cold crockpot, turn it on, and come back a couple hours later or the next day. You want the chain to be as warm as the wax for best adhesion. I use a bent coathanger inserted in chain prior to dunking to get it in and out. The gunk and dirt comes off and settles to bottom. Throw the wax away after it gets too dirty, a few dozen uses. Avoid KMC chains if you wax, they use a surface coating that the wax doesn't adhere to. https://zerofrictioncycling.com.au/wax-instructions/ - site is filled with useful stuff.
Greg Lepore 85 Targa 05 Ducati 749s (wrecked, stupidly) 2000 K1200rs (gone, due to above) 05 ST3s (unfinished business) |
I ride singlespeed all winter in the pnw woods. Golden rule is clean and lube chain before entering house, otherwise chain is rusted the next morning.
By far my best chain lube experience is a ‘cleaner lube’, it cleans and lubes at the same time. Hose chain down with lube, cycle chain 3-5 cycles then wipe it all off with a blue shop towel. Takes about… 90 seconds. Chain is kept shiny and spotless. Downside is you need to bring lube on longer rides. 30 miles on dusty dry trails, 8 miles if youre litarally riding up a creek. 50-80 miles of dry road riding. Brands to try: rock n roll extreme, or gold. One ball. The r&r extreme has a pint on amazon for a good price. Waxing sucks. Never ever will i do that again. Tons of prep but doesnt work in mud. The cleaner lubes are wax in solvents, solvents clean then dries leaving wax. |
