Question about the weight of things deep in the ocean
If a 20,000 ton displacement ship sinks to xx,000 feet to the sea floor, will it still weigh out at 20,000 tons at that depth? Assume no buoyant compartments or similar conditions.
Thanks, Bob |
More or less.
I'm smelling a trick question the likes that even Supreme Court Justice Ketanji Brown Jackson would answer as "I can't answer that as I'm not a naval architect."
gravity is pretty much the same, varies slightly with altitude, but yeah, mas o menos, lo mismo
I got your naval architect right here, and raise you a rocket surgeon. |
I have to assume that 1000# block of iron is going to weigh practically 1000# whether it's in orbit in the ISS, sitting in your driveway or at the bottom of the Mariana trench. Obviously, the weight of the water above the ship would be pushing down, but that water (much like air) is pushing on the ship from all directions. Gravity is still pulling on the metal that the ship is made of with roughly the same force. A quick google has provided that the difference in gravity from sea level to the top of Everest is 0.25%, and even at 200,000km, it's still 94% of sea level. |
Now hang on just a doggone minute..... a piece of a 2x4 floats because it displaces the weight of more water than it weighs.... am I right?
<iframe width="560" height="315" src="https://www.youtube.com/embed/IdBkVRjEr4Y" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe> |
Yeah, the pressure down there has nothing to do with it. Only the distance to the center of the earth.
It is closer, a thousand feet under the sea.
Thanks for your responses...:)
I read that salt water is more buoyant than fresh...and that water pressure is "more or less" applied evenly at any depth (thanks java and Steve) No one's weighing things on the surface and the deep ocean, right? I suspect the salt concentration reduces weight on the sea floor. Not sure where the difference is offset if water can't be compressed. |
If you ignore the buoyancy of the ship and consider pure gravity, the ship will weigh less down there because some of the earth's gravity is in the water which is now above the ship, the gravity of the water thereby now acting upwards upon it.
Sent from my SM-G988B using Tapatalk |
The mass doesn't change, obviously, but the weight (force) would be less due to buoyancy.
https://physics.stackexchange.com/questions/132935/gravity-beneath-sea-level
this sounds pretty good. Quote:
I need a free body diagram :D
Some of the first gravity experiments were done against a mountain (to Frost's point) to measure the affect of mass. And relative specific gravity of steel is 7.8 (to hbueno's point) meaning that the weight of the steel will be ~7/8ths of what it is on land. |
Just looked up the mountain gravity experiment - https://en.wikipedia.org/wiki/Schiehallion_experiment
Someone wanted a "free body diagram"? This is the best I could do:
http://forums.pelicanparts.com/uploa...1657084465.jpg |
A ship on the floor of the sea would be really difficult to lift... You'd have to deal with the suction.
(Depending on how long it's been there) |
| All times are GMT -8. The time now is 04:46 AM. |
