A930Rocket's Avatar
How to cut a 12 x 12 x 3/16 metal square diagonally?
What’s the best way to cut a 12” x 12” x 3/16 metal square diagonally? I’ve got a miter box that I could partially cut the diagonals using a metal cutting blade, but then I would need to connect the two cuts. Throw a metal cutting blade on my circular saw?
Then I want to round off the edges. Probably too much for my jigsaw, so maybe my cut off wheel?
Old 11-03-2022, 07:06 PM
Jeff Jagusch's Avatar
Shear
Find a local fabricator that has a shear, they should be able to make easy work of that!
Old 11-03-2022, 07:18 PM
A930Rocket's Avatar
Just remembered a steel fabrication shop we get flitch plates from. I’ll swing by tomorrow and see if I can at least get the diagonal cut.
Old 11-03-2022, 07:32 PM
David's Avatar
If you were near me I’d put it on the band saw.
Old 11-03-2022, 08:55 PM
Home of the Whopper
Angle grinder with cut off wheel.
Would have been done in time you took to ask!
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller
Old 11-04-2022, 10:15 AM
LASERS!
Ya need a CNC laser cutter. A friend of mine is a professional welder, and has his own company. He has a huge CNC plasma cutter table. It might be a bit of overkill to do that little piece.
Find a sheet metal shop with a shear, and have then cut it. It should be quick, easy and cheap and precise.
Old 11-04-2022, 11:10 AM
A930Rocket's Avatar
I forgot to take it with me to work today. Looks like I’ll be using the miter box and Skil saw. Stay tuned for pictures this weekend.
Old 11-04-2022, 11:39 AM
908/930's Avatar
Yup.
Old 11-04-2022, 11:58 AM
if it were me, I'd go after it with a chain saw.
Good thing you aren't me I guess.
Old 11-04-2022, 12:23 PM
Use a carbide chain for a cleaner cut!
How neat & clean does the diagonal cut need to be? That would dictate my approach... not 928 or 911 owners
Old 11-04-2022, 12:30 PM
You didn't mention how thick the material is. I have a plasma cutter that would probably cut that. The key would be to clamp some sort of guide bars along the cut line to make sure the cut is straight and accurate.
Old 11-04-2022, 12:33 PM
Low tech here.... I'd clamp a guide and use a hacksaw.
Old 11-04-2022, 12:44 PM
A930Rocket's Avatar
3/16.
I had a big shopping list at Lowe’s and I’ll be damned if I left the metal cutting blades on a shelf.
Old 11-04-2022, 01:05 PM
A930Rocket's Avatar
I would be long gone if I used a hacksaw.😂
Old 11-04-2022, 01:06 PM
Ayo Irpin, Ukraine!
70SATMan's Avatar
I think he did,,
Harmlessly passing gas in the grassland away;
Only dimly aware of a certain smell in the air
Old 11-04-2022, 01:07 PM
Like I said.... Not my problem ...
Does it need to be a neat cut?
Old 11-04-2022, 01:33 PM
Bill Douglas's Avatar
It depends on how exact and clean you want the cut. If it doesn't have to be perfect I'd use a cut off disk on an angle grinder.
Old 11-04-2022, 02:15 PM
But think how sweet your biceps would look in the open casket! Ask to be buried with a sleeveless shirt.
Rutager West
Old 11-04-2022, 02:22 PM
Shaun @ Tru6's Avatar
How to cut 5/8" steel plate like butter
Tru6 Restoration & Design
Old 11-04-2022, 02:52 PM
Platinum Member
dad911's Avatar
Hmmm..... depends on the closest tool to my reach. Sawzall, bandsaw, angle grinder..... would all get er done.
If you are into pain, use a dremel and alot of cut-off wheels.
Old 11-04-2022, 03:09 PM
