Don't open pool next year...what do I do?
Did a search....found nothing. I opened and closed my pool this year. Had it serviced regularly. Cost thousands for nobody to go in it! I am old and don't go in anymore. Next year, if i don't open it, I won't have to close it. It has a mesh cover. Anybody know what chemicals I have to put in next summer so it doesn't get too bad? I am planning on a separate pump to sort of circulate the water. Any advise is appreciated.
2001 911 Cabriolet |
Why does it cost thousands? I spent $279 on a bucket of chlorine tabs, which will last a year, not just a summer. I spent maybe $50 on other various chemicals. I DIY just about everything and enjoy it. Had I not switched from a DE to a cartridge filter and gotten a new Pool Cleaner, my costs would have been under $400. Even with the upgrades, which will last at least 10 yrs, I spent under $1500.
2022 BMW 530i 2021 MB GLA250 2020 BMW R1250GS |
Turn it into a turtle pond?
Why does it cost thousands? Opening, closing, chemicals, servicing etc. I used to take care of it myself. Comes a time when your physical capacity disallows that. As a younger person I could not understand what old people were going through. Now I can.
Turn it into a large deck - like Wayne Dempsey did to his. The thread is on Pelican.
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
Around. here you have to keep water in it so it does not rise up out of the ground. Otherwise, sure, just empty it.
Yes on deck! And get yourself a hot tub to put next to it. If you're old like me you'll use it a lot more than the pool
Counterclockwise?
I'd worry about what the summer heat will do to everything without water in it. Liner will sag without the pull being filled and seals will dry up.
I never found it much trouble and budgeted $1,000 a year which included a new cover etc. every 5 years.
Rod 1986 Carrera 2001 996TT A bunch of stuff with spark plugs Last edited by 911 Rod; 10-21-2022 at 11:08 AM.. |
If you're never going to use it again drain it, put a sump pump in it, and build a deck over it.
Counterclockwise?
Might be a violation of local codes.
Rod 1986 Carrera 2001 996TT A bunch of stuff with spark plugs |
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
Fleabit peanut monkey
When they drained my pool in Houston to refinish it they drilled several substantial (3" or so) holes through the gunite into the ground. I'm pretty sure this was to reduce the risk of it popping up.
1981 911SC Targa |
I'm known as Poolboy on another site. I'd love to help.
But I only give share trader advice. The Poolboy character is an 8 year old boy who hires the other kids in his class to clean the pools and pays them $25 for a days work and charges the pool owner between $800 and $1200 for the job. I say things like "I'm only 8 but as smart as a 10 year old." Haha, it really winds the old guys up on the share trader forum getting advice from an (apparent) 8 year old, and telling them where they have gone wrong and how much money I am making. But as far as your pool goes, sorry Poolboy can't help. |
Charlie 1966 912 Polo Red 1950 VW Bug 1983 VW Westfalia; 1989 VW Syncro Tristar Doka |
Banned
my pool has koi
a little air and change the water when you can't see them |
canna change law physics
https://www.troublefreepool.com/
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
Behind the Sun
First World Problems
Koi or turtles will save big dollars on chlorine. Neither one likes it.
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI |
Preferred pronoun:Maestro
Drain it and let the local skateboarders have at it.
_
When in doubt, use overwhelming force. |
