-   -   Riveting Question (http://forums.pelicanparts.com/off-topic-discussions/1130632-riveting-question.html)
Superman 11-28-2022 09:39 AM
Riveting Question
These are photographs of a rivet which attaches an eyelet to a boot. As you can see, the rivet is not properly installed. The photos show both sides of the rivet. I have a rivet gun and a box of rivets, but they are unlike this one. So....I do not understand how this rivet works or how to fix it. Here is what I wonder:
Could it be as simple as pressing this rivet further using my bench vise? Simply compressing it to the point where the ends of the rivet are flush with the eyelet and the leather? Would I need to use a special jig, or can I simply put this in a press with flat business surfaces, such as a vise?
http://forums.pelicanparts.com/uploa...1669657150.jpg
Evans, Marv 11-28-2022 10:26 AM
I'd try try vice technique or hydraulic press and use a washer on the inside part as a buffer. If that doesn't work, you can always drill it out & try buying a new one to press in. Maybe a grommet tool would work.
Superman 11-28-2022 10:30 AM
I just used the simple vise method, and it worked. Thanks, Marv.
Evans, Marv 11-28-2022 10:34 AM
Great! Being on the inside if there are any irregularities, it could potentially be an irritant against your foot or ankle.
Rusty Heap 11-28-2022 02:24 PM
Now try to do it 30 feet down in the puget sound while diving with tools.
