Senior Member
Superman's Avatar
Riveting Question
These are photographs of a rivet which attaches an eyelet to a boot. As you can see, the rivet is not properly installed. The photos show both sides of the rivet. I have a rivet gun and a box of rivets, but they are unlike this one. So....I do not understand how this rivet works or how to fix it. Here is what I wonder:
Could it be as simple as pressing this rivet further using my bench vise? Simply compressing it to the point where the ends of the rivet are flush with the eyelet and the leather? Would I need to use a special jig, or can I simply put this in a press with flat business surfaces, such as a vise?
Mocha 1978 911SC. "Coco"
Old 11-28-2022, 09:39 AM
I'd try try vice technique or hydraulic press and use a washer on the inside part as a buffer. If that doesn't work, you can always drill it out & try buying a new one to press in. Maybe a grommet tool would work.
Marv Evans
'69 911E
Old 11-28-2022, 10:26 AM
Senior Member
Superman's Avatar
I just used the simple vise method, and it worked. Thanks, Marv.
Old 11-28-2022, 10:30 AM
Great! Being on the inside if there are any irregularities, it could potentially be an irritant against your foot or ankle.
Marv Evans
'69 911E
Old 11-28-2022, 10:34 AM
Evil Genius
Rusty Heap's Avatar
Now try to do it 30 feet down in the puget sound while diving with tools.
Life is a big ocean to swim in.
Wag more, bark less.
Old 11-28-2022, 02:24 PM
