I have a few friends who absolutely excell at welding, a perfect row of dimes, super straight lines, can sign their names on aluminum much better than I can write.
Byron ![]() 20+ year PCA member ![]() Many Cool Porsches, Projects& Parts, Vintage BMX bikes too |
I’m in the process of adding metal flares to my 330. Before I even start welding there’s gonna be a lot of trial and error fitting everything up.
Last time I did welding, I practice on some scraps and it worked well but then when I went to weld, I had a difficult time with burning holes, not enough penetration or more importantly, building the weld up instead of stopping and trying again after grinding. This time I’m going to concentrate on small welds back-and-forth on the flare. ![]() ![]() Last edited by A930Rocket; 11-30-2022 at 05:41 PM.. |
I dunno... a lot of advice in this thread is about proper structural welding. But bodywork is a totally different deal. With bodywork you're going to weld through burning paint with dynamat still stuck to the back of the panel, use the gas purge to keep fires from starting.
Most important tip anyone ever gave me for bodywork was: put down a tack, then go work elsewhere until the area is warm to the touch. Go real slow and it won't warp. I have some old canadian land cruisers that sprout rust every so often. Here is my door panel before and after. ![]() ![]() |
Almost Banned Once
Mostly basic stick welding. I bought a gasless MIG welder a few years ago but I've barely use it.
I've been thinking about TIG but I don't have a project for it yet.
- Peter |
Recreational Mechanic
Land rover frame welding content from last week's episode:
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing |
I had been watching that but lost track of it for whatever reason. Thanks
Matthew - drove Nurburgring with wipers on and no rain 1969 911E SOLD ![]() 2002 996 Cabrio 1995 993 Carrera 4 SOLD 2004 Land Rover Discovery II G4 Edition (Sold ![]() |
Welding takes practice, and I'm out of practice.
After botching a few jobs I learned to get some scrap out and brush up on my technique before trying the actual job. I learned to gas weld in 1969 so I could weld a new floor in my first Porsche. I haven't used the torches for welding since and I'm not sure I could do it anymore. One of my summer jobs in college was production welding trailers together with a MillerMatic mig welder. I laid down miles of beads and got pretty good, but I still have to brush up before I do a real welding job.
Navin Johnson
Same principles apply..... clean base metal, and good fit... For sheet metal, I use punches , crimpers, flangers, even rivets to fit up the pieces before I even strike an arc.. (grind the rivets off and rosette weld, metal finish after your repair is done ) Door jamb repair of '69 911 This was actually rocker replacement. jack point replacement, kidney (fender support), and door jamb.... all sheet metal.. many rosette welds many seam welds.. ![]() Bent a piece of sheet metal on a brake Repair piece welded in Shrink and stretch.. Shrink and stretch. Rosette welds on flange.. you can see on the kidney I did seam welding.... get your settings right and good fit up and move... Almost done... the rear quarters on this car were Dzused on so I just made the flange a bit longer
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others Last edited by TimT; 11-30-2022 at 02:52 PM.. |
I’ve purchased a Mig n Tig with the intent of teaching myself for 912 repairs I need to make. Local CC welding classes fill up in hours, so I haven’t been able to re-roll in a class.
I found a great YouTube channel on welding and I like it so much, I’ve purchased some of his series. All his videos are posted on his channel “Welding Tips n Tricks” Sent from my iPhone using Tapatalk
"What the hell is an Aluminum Falcon??" -Palpatine (Robot Chicken) 1978 911SC Targa Working Projects: 1968 912 |
That looks great!!!!!! Sent from my iPhone using Tapatalk
On my next project I decided I wanted cleaner work, less brittle welds, and much less grinding. I went out and bought a TIG. Set it up, and called s good friend who I knew was a very accomplished TIG welder to show me how to use it. He showed up that afternoon with a couple of gas bottles and a very small oxyacetylene torch. He said he wouldn’t waste his time trying to teach me the TIG until I could weld sheet metal with a torch. Best advice welding advice I ever got. Learned with the torch to read the metal, watch what has happening as the metal flowed together, control heat with the torch and the rod, move the puddle around, etc. truly welding. You really can’t see any of that stuff with a MIG. Eventually I got pretty comfortable with the torch, and moved on to the TIG. I use it for 90% of my welding now. The other 10% I do with the gas torch, because it’s fun, helps my TIG welding be better, and just occasionally it’s the only tool for the job. Haven’t touched the MIg in 15 years. |
When welding two pieces of sheet metal, a good ground is obvious but would it hurt to put a ground clamp on both pieces to make sure it’s grounded properly?
In my case, I’m trying to ground sheet metal flares to my car. I can put the ground clamp on the flare but what about the car? Would it hurt to make a jumper from the ground clamp to the car? |
No need to put a ground on both A930Rocket, usually if they are clamped together that covers it, or once the puddle touches.
87 930, Last edited by 908/930; 12-02-2022 at 08:34 AM.. |
Leadfoot Geezer
How not to do it...
'67 912, '70 911T, '81 911SC, '89 3.2 Targa - all sold before prices went crazy '13 BMW 335i coupe - current DD '67 VW Karmann Ghia convt. & '63 VW Beetle ragtop - ongoing projects |
Do some practice welds before actually welding on your car. The puddle needs space to expand so leave a gap for puddle to fill. |
UnRegistered User
I am not the weldor
I am the weldor's son. I will do the welding until the weldor comes. I can hold my own with a stick welder but need to do some work with the mig. Going to try tig welding in the near future.
Bill K. "I started out with nothin and I still got most of it left...." 83 911 SC Guards Red (now gone) And I sold a bunch of parts I hadn't installed yet. |
I have done basic stick and mig, but that was 20 years ago. I could tack the hell out of two things!
Now, at work, I have access to stick, mig, tig, aluminum welding, stud welding, rosette welding, brazing and every type of metal forming/cutting/bending machine there is. I also have access to 3 trained professional welders, so I'll let them do it. ![]()
Mike Bradshaw 1980 911SC sunroof coupe, silver/black Putting the sick back into sycophant! |
I bought a SC muffler from a fellow Pelicanite and it was too big for the cheap rate box so he cut the tail pipe off. A guy I worked with was a food grade welder and he stainless steel welded the tailpipe back on. I really had trouble finding the weld it was so perfect. |
Thread Tools | |
Rate This Thread | |
