What?
Fiberglass fuel tank?
I'm building the Tamiya Porsche 934 model and doing some research and came across some pictures of the fuel tank. Looks fiberglass to me. Wouldn't fuel eat that away? Did they coat the inside with something else?
________________________________________ Eric Hahl 85 911 to 73RS backdate, a.k.a. "Gretchen" (SOLD) 2015 981 Cayman S (Sold) 23 Outback Wilderness & 23 BMW R1250GS |
Parrothead member
A few year back, a lot of boats were using FG fuel tanks. Once they introduced the ethanol crap they started having issues with the tanks disintegrating.
Vinny Red '86 944, 05 Ford Super Duty Dually '02 Ram 3500 Diesel 4x4 Dually, '07Jeep Wrangler '62 Mercury Meteor '90 Harley 1200 XL "Live your Life in such a way that the Westboro Baptist Church will want to picket your funeral." |
What?
I would have thought the resin would get eaten away. Learn something every day.
Almost Banned Once
Yes it was FG but it has a bladder inside.
(FWIW A Ferrari F40 fuel tank bladder has a service life of 10 years)
- Peter |
Model Citizen
Lots of dirtbike tanks in the '70s were fiberglass. Once Preston Petty made his famous front fender available though, that horse was out of the barn.
"I would be a tone-deaf heathen if I didn't call the engine astounding. If it had been invented solely to make noise, there would be shrines to it in Rome" |
Parrothead member
They never had any issues until the ethanol.
I have a carbon fiber tank on my 1993 Ducati 900 SS. Same laminating resin as would be used to make a fiberglass tank, a two part epoxy of some kind. Many old British bikes used fiberglass tanks as well. And, as Vinman says, lots of boats are built with them. I believe some light aircraft may use them as well.
The two part epoxy laminating resins hold up just fine. Unfortunately, most of these tanks are built in two pieces that must be joined somehow. My tank is a kind of "tortoise shell", as are most motorcycle tanks, with the visible top part all one piece and a more or less flat bottom, with a flange around it, inserted underneath. The seam is then glued with whatever the manufacturer chooses. It turns out that these glued seams are the failure point. In my case, and in the case of many boats, ethanol based fuels dissolved whatever glue was used. I had to separate mine and re-glue it with something ethanol proof (I used JB Weld). Imagine this problem in a fiberglass boat, where many tanks are laminated into the hull after being glued together. For the most part impossible to repair. So, yeah, the laminating resins hold up just fine, even to ethanol. The real lynchpin is whatever was used to glue the two halve together.
Jeff '72 911T 3.0 MFI '93 Ducati 900 Super Sport "God invented whiskey so the Irish wouldn't rule the world" |
What?
Thank you! Exactly what I wanted to know. Now I know how to paint it to make it look real.
When I first started doing track days in my 911, we had a guy who actually took his Ferrari F40 out on the track. We all watched that car burn literally to the ground when one of those fiberglass tanks failed. The driver and instructor were lucky to get out alive. He never hit anything, had no incident of any kind that would have ruptured it. It simply failed and dumped all over the exhaust. Drivers following it, and the corner marshals, saw it was on fire long before the occupants knew. By the time they figured it out and got the car stopped it was over. Totally engulfed. Amazing they got out.
Almost Banned Once
This is the scene of a crash in Australia. Note: You can see the fuel tank but there's no obvious fuel leak. ![]() ![]()
- Peter |
74 911Ebay
So the 934/935's had fiberglass fuel tanks, aluminum roll cages, powerbands that gained hundreds of HP in a couple hundred RPM.
what a time
The world needs more Protest Singers |
Skip Newsom's Commando has a fibreglass tank that would be nearly 50 years old. So must be OK. Surprising though.
The Norton Commando I bought new in 1972 or so (not 100% of the year, it had the Combat engine) had a fiberglass tank. I got hit by a truck from the side and my foot broke the petcock out of the tank. The same year replacement Commando I got new had a steel tank.
More Likeable IRL
Ol uncle Lee was not such a good rider and within 3-4 rides the thing was trashed. broken, shattered body work hanging and falling off while blowing in the wind...
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
Been used in fuel tanks for decades..... Marine, motorycyle and yes, some automotive....
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Almost Banned Once
Not like this.
- Peter |
Super Moderator
Wait - so thats the model?!
Model Citizen
The orange one above is the model.
I just figured out how they get that enormous bladder into that tank...du'h.
"I would be a tone-deaf heathen if I didn't call the engine astounding. If it had been invented solely to make noise, there would be shrines to it in Rome" Last edited by herr_oberst; 01-07-2023 at 02:49 PM.. |
