Registered ConfUser
Glass Cooktop - Uh oh…
36” Induction Cooktop took a hit to the corner from a dropped can of cooking spray. Before spending a small fortune to replace the entire thing…any ideas? Obviously my attempt at gluing it back together was a failure.
Old 12-30-2022, 06:35 AM
rfuerst911sc's Avatar
You said your glue job was a failure please explain . Did the glue not hold ? Or it held but you don't like the looks ? I assume all burners still working ?
If it's cosmetic you can probably do some " body work " and paint gloss black . It won't be perfect but better than it is now . Maybe call GE and see if a repair kit is available ?
Old 12-30-2022, 07:14 AM
Model Citizen
herr_oberst's Avatar
I'd live with it and let that logo be a reminder. Then when the stovetop finally gave up the ghost, and it was time to spend the money on a new one, I'd know I'd have at least one brand I could ignore in the showroom.
That's just me. I'm very cynical.
Old 12-30-2022, 07:15 AM
Congratulations. Now you have an excuse to replace it with a proper gas cooktop.
I suspect that the glass top is not replaceable but I have no idea. Call the customer service number for GE and ask them. While you’re on the phone with them, ask them what the tops are made of, I’ve never been able to figure out how they handle the thermal stresses in those.
Old 12-30-2022, 07:28 AM
You might try brushing some high temperature epoxy into the divot and cracks and then wet sand that down to match the rest of the surface.
Old 12-30-2022, 07:38 AM
I may have spoken too soon. Maybe you can replace these tops:
https://www.hgtv.com/design/rooms/kitchens/remove-glass-cooktop
Old 12-30-2022, 07:52 AM
What?!?!
DonDavis's Avatar
I have a glass cook top and just morning I was polishing it.
Keep wondering when I'll break it. Curious to see if you repair it.
running shoes, couple tools, fishing pole
1996 Subaru Legacy Outback AWD, 5speed
2002 Subaru Impreza WRX, 5speed
2014 Tundra SR5, 4x4
1964 Land Rover SII A 109 - sold this albatross
Old 12-30-2022, 08:30 AM
We have a GE glass 4 burner gas cooktop with downdraft exhaust. What a POS! It has a SS trim piece surrounding the whole glass, held on with double sided tape from the factory. First time my wife washed the top after cooking the trim piece came right off. I ended epoxy glueing the trim piece back on. When downdraft is running it “pulls” the flame off the burner. Piss poor design and engineering. The only reason we bought it was there were only two manufacturers offering downdraft exhaust. Wife hates the thing, next spring new cooktop. Maybe Kitchen Aid or Jenn Air. Stay away from GE, real garbage and it was made in the USA.
Old 12-30-2022, 09:26 AM
Never use a downdraft exhaust on any cooktop.
Old 12-30-2022, 09:39 AM
Downdraft
Uhh Java,
It was designed that way. Jenn Air also has a downdraft, worked great. High end cooktops have them as well. Wat are you basing that comment on?
Old 12-30-2022, 11:32 AM
They just don’t work as effectively as overhead vent hoods. Steam, smoke, and all that naturally wants to rise.
The house I’m in now was originally fitted with something like that, I intercepted the duct in the wall behind the cooktop and plugged in a normal range hood.
It depends on what you cook and how much of it, it might be adequate for some things but nowhere near adequate for others.
Old 12-30-2022, 11:49 AM
Bill Douglas's Avatar
I was able to just buy the top for my glass cooktop. Worth a try.
Old 12-30-2022, 12:28 PM
A930Rocket's Avatar
We have replace the glass on glass cooktops several times over the years while building houses. I am amazed at how simple it’s attached…. Glue of some kind or silicone. Do a Google search and see if the part is available
Old 12-30-2022, 12:30 PM
You didn't saw what kind of glue you used, but I have used this product with glass repairs and it works really great!
Old 12-30-2022, 01:02 PM
Shaun @ Tru6's Avatar
Tru6 Restoration & Design
Old 12-30-2022, 01:16 PM
greglepore's Avatar
Agree totally. Ditched an expensive Dacor downdraft the minute we moved in here for a relatively inexpensive zline 40 in hood.
Greg Lepore
85 Targa
05 ST3s (unfinished business)
Old 12-30-2022, 01:23 PM
Registered ConfUser
I used some super glue (gorilla) and it held fine, just looks bad. Also, being an induction stove, it doesn’t get very hot...even the burner. It’s the pan that gets hot, not the burner, if that makes sense. Will look into replacing the glass top. Wouldn’t have thought of that.
Mike
Old 12-30-2022, 01:31 PM
Our kitchen is small, no room for a hood above the range. Exhaust fan direct vent to outside. One elbow and a straight shot to outside wall, about 3’ of pipe and one ell. It does the job for us.
Old 12-30-2022, 03:26 PM
Platinum Member
dad911's Avatar
Windshield glass chip repair?
Old 12-30-2022, 07:04 PM
