Still Doin Time
asphaltgambler's Avatar
Issue with Toilet - PPOT Braintrust
I'm pretty good with basic plumbing, but this one is puzzling me. We bought this toilet @5 years ago. It is low flow / dual flush. It is the guest / hallway bathroom so we rarely use it. About 6 months ago we both noticed a stale 'urine' smell near the toilet. My wife is OCD Mrs clean and is very detailed when she does. So I cleaned the top tank and added a few drops of bleach, but there really wasn't any smell from there. I set the water level in the tank = OK. The seal on bottom is not leaking, no smell from there.
Here is something that is odd and unusual. The water level in the bowl is lower than in the past. So I removed the tank lid, flushed and watched the flow of water into the fill tube. It was strong, continous until the float shut the feed off. I raised the float level just above the max and did several flushes but water level in bowl remains the same.
So, I filled a separate container with water and slowly poured in the bowl, raising the level slightly. I then watched as the water drained back to the lower level. See pix below.
So something has changed, the bowl water level is @1" lower than it should be, and possibly exposing the sewer gasses from below. We have 3 toilets, on a 1 level ranch home. The other two have no issues with smell or bowl water level.
I'm at a loss, as to why the bowl water level is lower fo some reason, and is draining back when I add just a little bit of water and the smell. What say y'all?
Old 01-02-2023, 04:09 PM
I have never used or seen a black toilet .... mebbe it's Satanic? Are the others black ?
Old 01-02-2023, 04:14 PM
I see you
flatbutt's Avatar
Did you clean the water inlet holes? I once heard that a clogged sewer vent can result in low water but I don't see how.
Old 01-02-2023, 04:16 PM
If the water level is controlled by the inlet valve...turn the adjustment clockwise to raise the water level
A full turn will result in about an inch level.
78 SC Targa Black....gone
84 Carrera Targa White
98 Honda Prelude
22 Honda Civic SI
Old 01-02-2023, 04:22 PM
Still Doin Time
The only black toilet in the house. Matches the black sink counter top, modern decor. No water backing up in fill tube when the line is pouring in. Again, I can add water manually to the bowl water level but it starts draining almost immediately to the now lower level.
Old 01-02-2023, 04:37 PM
I see you
flatbutt's Avatar
Could a partially clogged trap cause a siphon?
Old 01-02-2023, 04:44 PM
No trap way under there, trap is part of the toilet.
Check your vent. Maybe its fill with leaves or a dead animal trying to stay warm?
Old 01-02-2023, 04:48 PM
I see you
flatbutt's Avatar
I thought that too but I don't understand the physics of that.
Old 01-02-2023, 04:49 PM
Check it’s not partially blocked.
Our downstairs half-bath head does what you are describing after one of the kids drops too much paper. It’ll flush a bit slower but then it settles with the level a bit lower.
A little quality time with a plunger has it back to normal.
Old 01-02-2023, 05:47 PM
thinking about the times when you were feed beer through a tube back in college. The hole up top is the vent. If the vent is clogged (depending on how bad?), the water lever will eventually come back up to normal.
Crack in the toilet? But not sure how that wouldn't be evident. And the stale pee smell is weird since it looks like it's got enough water to block any fumes from the sewer.
Maybe pop it off and put a new wax ring on just in case? Messy job, but easy.
Old 01-02-2023, 05:51 PM
Try replacing the little fill flexible fill pipe/line.
Or at least examine it for any clogging or damage.
The other possibility is the vent pipe that runs the gases out to your roof. Not sure how to check that but worth checking....
Old 01-02-2023, 05:58 PM
Get the ladder out and a flash light. Have some one flush and keep an eye out or block the vent with hand, try and feel for slight vacuum. Be careful on the way up and down. I fail to understand the pee smell. Maybe a cracked bowl. Steve is right on this.
Old 01-02-2023, 06:01 PM
MBAtarga's Avatar
All the search results I see mention the same suggestions above - a clog, a vent issue, or a crack in the toilet.
I also learned something - "Contrary to popular belief, the plunger is NOT meant to force a clog down the drain. Plungers are meant to be used to create suction in the toilet trap, causing the blockage to break up and then flow down the drain when the plunger is pulled out of the bowl. Pushing hard on a plunger usually just blows out the wax seal between the toilet and the flange. Then the toilet has to be pulled and resealed."
Mark
'83 SC Targa - since 5/5/2001
Old 01-02-2023, 06:14 PM
Old 01-02-2023, 06:18 PM
Like this?
Old 01-02-2023, 06:20 PM
I'd suspect a crack either in the trap or down by the wax ring. If small enough, it could seep out slowly enough to dry up and leave a slight uring smell.
Marv Evans
'69 911E
Old 01-02-2023, 09:46 PM
Still Doin Time
Thanks guys
Old 01-03-2023, 05:04 AM
Im with Marv's guess.
Old 01-03-2023, 11:16 AM
I suspect that the smell is from incomplete flushing, aka back-wash.
The system is not completely eliminating the urine and it builds up and smells.
Get rid of that complicated $80 flush mechanism.
It is not working well and will only cause
more problems.
Convert the toilet back to a conventional flapper-style.
it's easy to do and should cost less than $30
but you will have to remove the tank to do it.
EDIT I just re-read the OP and the above diagnosis would not
explain the lower static water level.
That lower level could only be caused by a crack in the toilet
allowing water to drain to the current level (unlikely, never seen that before)
or caused by excessive syphoning.
That could be why the above comments about venting are relevant.
I would still get rid of that POS water saving flush system
Old 01-03-2023, 11:51 AM
