Still Doin Time
Issue with Toilet - PPOT Braintrust
I'm pretty good with basic plumbing, but this one is puzzling me. We bought this toilet @5 years ago. It is low flow / dual flush. It is the guest / hallway bathroom so we rarely use it. About 6 months ago we both noticed a stale 'urine' smell near the toilet. My wife is OCD Mrs clean and is very detailed when she does. So I cleaned the top tank and added a few drops of bleach, but there really wasn't any smell from there. I set the water level in the tank = OK. The seal on bottom is not leaking, no smell from there.
Here is something that is odd and unusual. The water level in the bowl is lower than in the past. So I removed the tank lid, flushed and watched the flow of water into the fill tube. It was strong, continous until the float shut the feed off. I raised the float level just above the max and did several flushes but water level in bowl remains the same. So, I filled a separate container with water and slowly poured in the bowl, raising the level slightly. I then watched as the water drained back to the lower level. See pix below. ![]() ![]() ![]() ![]() So something has changed, the bowl water level is @1" lower than it should be, and possibly exposing the sewer gasses from below. We have 3 toilets, on a 1 level ranch home. The other two have no issues with smell or bowl water level. I'm at a loss, as to why the bowl water level is lower fo some reason, and is draining back when I add just a little bit of water and the smell. What say y'all?
'15 Dodge - 'Dango R/T Hauls groceries and Kinda Hauls *ss '07 Jeep SRT-8 - Hauls groceries and Hauls *ss Sold '85 Guards Red Targa - Almost finished after 17 years '95 Road King w/117ci - No time to ride, see above '77 Sportster Pro-Street Drag Bike w/93ci - Sold |
I have never used or seen a black toilet .... mebbe it's Satanic? Are the others black
I see you
Did you clean the water inlet holes? I once heard that a clogged sewer vent can result in low water but I don't see how.
Si non potes inimicum tuum vincere, habeas eum amicum and ride a big blue trike. "'Bipartisan' usually means that a larger-than-usual deception is being carried out." |
If the water level is controlled by the inlet valve...turn the adjustment clockwise to raise the water level
A full turn will result in about an inch level.
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI |
Still Doin Time
The only black toilet in the house. Matches the black sink counter top, modern decor. No water backing up in fill tube when the line is pouring in. Again, I can add water manually to the bowl water level but it starts draining almost immediately to the now lower level.
I see you
Could a partially clogged trap cause a siphon?
I see you
I thought that too but I don't understand the physics of that.
Check it’s not partially blocked.
Our downstairs half-bath head does what you are describing after one of the kids drops too much paper. It’ll flush a bit slower but then it settles with the level a bit lower. A little quality time with a plunger has it back to normal. |
thinking about the times when you were feed beer through a tube back in college. The hole up top is the vent. If the vent is clogged (depending on how bad?), the water lever will eventually come back up to normal.
Crack in the toilet? But not sure how that wouldn't be evident. And the stale pee smell is weird since it looks like it's got enough water to block any fumes from the sewer.
Maybe pop it off and put a new wax ring on just in case? Messy job, but easy.
Try replacing the little fill flexible fill pipe/line.
Or at least examine it for any clogging or damage. The other possibility is the vent pipe that runs the gases out to your roof. Not sure how to check that but worth checking....
Old dog....new tricks..... |
Get the ladder out and a flash light. Have some one flush and keep an eye out or block the vent with hand, try and feel for slight vacuum. Be careful on the way up and down. I fail to understand the pee smell. Maybe a cracked bowl. Steve is right on this.
All the search results I see mention the same suggestions above - a clog, a vent issue, or a crack in the toilet.
I also learned something - "Contrary to popular belief, the plunger is NOT meant to force a clog down the drain. Plungers are meant to be used to create suction in the toilet trap, causing the blockage to break up and then flow down the drain when the plunger is pulled out of the bowl. Pushing hard on a plunger usually just blows out the wax seal between the toilet and the flange. Then the toilet has to be pulled and resealed."
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
I'd suspect a crack either in the trap or down by the wax ring. If small enough, it could seep out slowly enough to dry up and leave a slight uring smell.
Marv Evans '69 911E |
Still Doin Time
Thanks guys
Im with Marv's guess.
I suspect that the smell is from incomplete flushing, aka back-wash.
The system is not completely eliminating the urine and it builds up and smells. Get rid of that complicated $80 flush mechanism. It is not working well and will only cause more problems. Convert the toilet back to a conventional flapper-style. it's easy to do and should cost less than $30 but you will have to remove the tank to do it. EDIT I just re-read the OP and the above diagnosis would not explain the lower static water level. That lower level could only be caused by a crack in the toilet allowing water to drain to the current level (unlikely, never seen that before) or caused by excessive syphoning. That could be why the above comments about venting are relevant. I would still get rid of that POS water saving flush system Last edited by red 928; 01-03-2023 at 11:58 AM.. |
