-   -   Oil filter removers - is there a system? (http://forums.pelicanparts.com/off-topic-discussions/1134258-oil-filter-removers-there-system.html)
Bob Kontak 02-04-2023 02:51 PM
I'm talking about the round caps that you use a 3/8" ratchet or extension to remove the filter.
Is there references on the filter and the caps that would allow me to know which ones mate?
I hope this ends up being a stupid question and there is a system because I just chuck them all in a tub and dig for one that fits.
http://forums.pelicanparts.com/uploa...1675551090.jpg
porsche930dude 02-04-2023 02:58 PM
I use the 3 jaw style it clamps down as you turn it. Pretty much always works http://forums.pelicanparts.com/uploa...1675551442.png
astrochex 02-04-2023 02:58 PM
I like your current system. :D
LEAKYSEALS951 02-04-2023 03:03 PM
How big is your tub/ bucket?
KFC911 02-04-2023 03:03 PM
After the one pictured in the OP, then a strap wrench, then a screw driver through the filter (messy), I use "Big AZZ" Channel locks ..... that's my systen ;)
True story for the first time I removed the filter on my 911 btw. Ever since I just use the first one....
flatbutt 02-04-2023 03:05 PM
BACls every time.
LEAKYSEALS951 02-04-2023 03:07 PM
Originally Posted by flatbutt (Post 11914492)
BACls every time.
I find positioning myself directly under the filter gives the best leverage.
zakthor 02-04-2023 03:07 PM
$10 strap wrench
Bob Kontak 02-04-2023 03:09 PM
I probably have 15 of them but I don't think that's even close to the number of sizes available.
LEAKYSEALS951 02-04-2023 03:13 PM
15?!?!? :eek:
That deserves a redneck sheet of plywood with long screws in it on the wall (or somewhere) with the filters arranged from big to small or something. You can't be fishin' through 15 filters like that!
(edit- I use a strap wrench myself, with the correct open end wrench sitting right next to it.)
GH85Carrera 02-04-2023 03:15 PM
For my El Camino I have one kinda like the one in the first post.
For the Porsche, that same adapter would work, only if I had the space by removing the air filter. So I just use a strap wrench to get it loose, and then my fingers. I just tighten it down with my hands.
Oil filters are every size possible so no standard except large Channel locks, or strap wrenches. No way to get a strap wrench on some like my El Camino. Just the end socket.
KFC911 02-04-2023 03:17 PM
Everyone needs "Big Azz" Channel locks just because that's stamped on them ... I LOL'd when I saw them .... a must have :D
LEAKYSEALS951 02-04-2023 03:44 PM
Here's what you want. "It's what every white boy off the lake wants"
Make a delivery system similar to a beer flight board which you can carry right under the car and start trying filter tools. Too small- reach over and grab a larger one...or vice versa etc....
When you know what car a filter works on, write it on the board.
But you don't want four boards, only one, with handles, that holds all 15 and the wrench, like a TV dinner tray.
http://forums.pelicanparts.com/uploa...1675554108.jpg
JackDidley 02-04-2023 03:49 PM
+ 1 for Chanel Locks.
KNS 02-04-2023 04:09 PM
I have one of these and and it will defeat anything. Channel Locks are great but if you look at the small oil filter on the 993 access is really tight. The three claw job can get into that tight space.
Bugsinrugs 02-04-2023 06:43 PM
Until the rubber ends disappear. Then they no work.
Bill Douglas 02-04-2023 06:51 PM
Originally Posted by Bob Kontak (Post 11914483)
I had, well... have, one of these. It's currently stuck on the Corolla's oil filter. It's on but spinning around and I can't get it or the filter off.
I've bought a better on made of moulded aluminium, whereas the stuck one is pressed steel, but I have to get it off first.
Luckily the SC has excellent access to the oi filter and I have a remover that looks like a handle with a length of bicycle chain that wraps around it and tightens as you turn it. Works well.
Noah930 02-04-2023 08:17 PM
LOL. :D
I've used answer E: All of the above.
I think I have acquired about 8 or 9 different wrenches/ratchets/3-prong thingies over the years. And then, sometimes vampire-style (screwdriver through the filter) is the way to go.
pwd72s 02-04-2023 09:17 PM
2 cup thingies, 2 sizes of steel band wrenches, a pair of oil filter pliers, AND a set of big ass 18" Craftsperson chan-l-locks...all in my rollaway.
And today? To the dealerships, write a check, drive home.
Noah930 02-05-2023 12:09 AM
Anyone else like the little moulded in "nut" at the end of K&N filters because of this?
