Oil filter removers - is there a system?
I'm talking about the round caps that you use a 3/8" ratchet or extension to remove the filter.
Is there references on the filter and the caps that would allow me to know which ones mate? I hope this ends up being a stupid question and there is a system because I just chuck them all in a tub and dig for one that fits. http://forums.pelicanparts.com/uploa...1675551090.jpg |
I use the 3 jaw style it clamps down as you turn it. Pretty much always works http://forums.pelicanparts.com/uploa...1675551442.png
I like your current system. :D
How big is your tub/ bucket?
After the one pictured in the OP, then a strap wrench, then a screw driver through the filter (messy), I use "Big AZZ" Channel locks ..... that's my systen ;)
True story for the first time I removed the filter on my 911 btw. Ever since I just use the first one.... |
$10 strap wrench
That deserves a redneck sheet of plywood with long screws in it on the wall (or somewhere) with the filters arranged from big to small or something. You can't be fishin' through 15 filters like that! (edit- I use a strap wrench myself, with the correct open end wrench sitting right next to it.) |
For my El Camino I have one kinda like the one in the first post.
For the Porsche, that same adapter would work, only if I had the space by removing the air filter. So I just use a strap wrench to get it loose, and then my fingers. I just tighten it down with my hands. Oil filters are every size possible so no standard except large Channel locks, or strap wrenches. No way to get a strap wrench on some like my El Camino. Just the end socket. |
Everyone needs "Big Azz" Channel locks just because that's stamped on them ... I LOL'd when I saw them .... a must have :D
Here's what you want. "It's what every white boy off the lake wants"
Make a delivery system similar to a beer flight board which you can carry right under the car and start trying filter tools. Too small- reach over and grab a larger one...or vice versa etc.... When you know what car a filter works on, write it on the board. But you don't want four boards, only one, with handles, that holds all 15 and the wrench, like a TV dinner tray. http://forums.pelicanparts.com/uploa...1675554108.jpg |
+ 1 for Chanel Locks.
I've bought a better on made of moulded aluminium, whereas the stuck one is pressed steel, but I have to get it off first. Luckily the SC has excellent access to the oi filter and I have a remover that looks like a handle with a length of bicycle chain that wraps around it and tightens as you turn it. Works well. |
I've used answer E: All of the above. I think I have acquired about 8 or 9 different wrenches/ratchets/3-prong thingies over the years. And then, sometimes vampire-style (screwdriver through the filter) is the way to go. |
2 cup thingies, 2 sizes of steel band wrenches, a pair of oil filter pliers, AND a set of big ass 18" Craftsperson chan-l-locks...all in my rollaway.
And today? To the dealerships, write a check, drive home. |
Anyone else like the little moulded in "nut" at the end of K&N filters because of this?
^^^ That's the main reason I buy their filters. Hardly ever need to use a wrench to loosen them.
I also have several strap wrenches that work well also . And finally I do have the big a$$ Channel lock as a final resort . My wife's Volvo XC90 has a cartridge style filter . The filter housing has a 3/8 ratchet nut as part of the housing . I think that is a smart design . |
For machinery and HD applications; I wouldn't touch fram but light duty appliance cars... eh |
I’m not aware of any magic markings on oil filters but there are lists of applications for some filter wrench brands, like this one:
https://www.eastwood.com/images/pdf/vehicle_fit_guide_oil_filter_wrench.pdf |
And once you've thoroughly screwed the pooch...;)
https://www.youtube.com/watch?v=lCBKbX7HitE&ab_channel=MoonlightfordF100 |
I've never been stopped from removing a filter with this thing....
http://forums.pelicanparts.com/uploa...1675628743.jpg And no...you don't need to be at a right angle to use it. As long as you can snake it in below the filter....it will grab it and work. |
Looks like Pops has a crush on Britney Spears.😂
I’ve always heard/read Fram filters are the bottom of the barrel. True or old wives tale?
40 years ago, that was the rumor...maybe true.
If they haven't improved since then....I doubt they would be the biggest seller of oil filters now. I have always used them, and never a problem. |
The oil filter change in my 330 went from easy to time consuming.
Easy. http://forums.pelicanparts.com/uploa...1675630201.jpg The six cap screws need to be removed and the top portion twisted off using two screws and a prybar. But the good news is, I have an oil cooler now. http://forums.pelicanparts.com/uploa...1675630241.jpg |
which filter? 20 minutes of comparison of new filters cut open.
<iframe width="1268" height="713" src="https://www.youtube.com/embed/ylw_-ZZLWr4" title="This Oil Filter DESTROYED My Engine Wix xp, Mobil1 or Fram ?" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" allowfullscreen></iframe> |
Now I need to watch that video. Edit: Watched it and the basic Fram is paper filtering material. I buy oil with the filter in a bundle from Advance Auto. The Fram Titanium is maybe $2 extra. I always but that one unless I'm going Mobile 1 and then I buy the Mobile 1 filter. Here is a more in depth look at the higher end Frams. <iframe width="560" height="315" src="https://www.youtube.com/embed/d5ULRcCNy5E" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" allowfullscreen></iframe> |
I always buy the OEM factory Porsche filters for my cars. Buy them 6 at a time. I don't trust other filters.
I have that same oil filter cutter. I do inspect the 911 filter on occasion after it has been used. That is a messy job looking for sparkly bits. So far very little sparkles in the filter material. In that first video the guy sounds rather southern. I just wonder if he bought the filters from store in Louisiana or a very humid area. Storing a metal part in a warehouse will cause many parts to rust. It is sad the manufacturers don't put some coating of oil or something compatible with engine oil in the filter to keep rust from forming. Just more money I guess.
I have used Wix filters for my El Camino for as long as I can remember, and the MANN or Porsche filters on my 911. For my wife's Macan, it has a cartridge filter, and I get the filter and the o-rings and new drain plug from the dealer. |
https://bobistheoilguy.com/forums/threads/so-fram-filters-why-the-bad-rap.222539/page-3 |
| All times are GMT -8. The time now is 10:46 AM. |
