Driver
Noah930's Avatar
Oiling the filter gasket
Is it really necessary to smear a little motor oil on the oil filter's rubber gasket during an oil change? I've always done it, because that's what I've been told to do. But if I didn't, does oil really leak from this junction? Too lazy to not do it and clean up any resultant mess.
1990 Black 964 C2 Targa
Old 02-05-2023, 02:32 PM
John Rogers's Avatar
yes. wet it with some oil
John
Old 02-05-2023, 02:35 PM
It will enable you to hand tighten it on further than if you hadn't oiled it.
A good practice to maintain.
78 SC Targa Black....gone
84 Carrera Targa White
98 Honda Prelude
22 Honda Civic SI
Old 02-05-2023, 02:36 PM
Model Citizen
herr_oberst's Avatar
I always slop a couple of glugs of oil into the filter anyway, kind of a primer. Some always gets onto the 0 ring and I smear it around with my finger, make sure the threads are coated in oil.
I'd never put a dry filter onto an engine.
Old 02-05-2023, 02:46 PM
Driver
Noah930's Avatar
I guess my question is: has anyone ever not oiled the gasket? What happens?
Old 02-05-2023, 02:49 PM
A930Rocket's Avatar
I read it on the Internet, so it must be true.
Old 02-05-2023, 02:50 PM
Model Citizen
If nothing else it could potentially make it a ***** to remove.
Old 02-05-2023, 02:53 PM
It would not be a catastrophe....as long as it was tightened down..no leaks.
It just makes everything easier with a little lube.
98 Honda Prelude
22 Honda Civic SI
Old 02-05-2023, 02:54 PM
pwd72s's Avatar
Usually there is enough oil left on the filter housing, the car part itself, to lube the gasket. But I always oiled anyway under the old "can't hurt, might help" mode...
Old 02-05-2023, 03:06 PM
MBAtarga's Avatar
The way I figure - placing the thin layer of oil helps to equalize the clamping force against the gasket when you tighten the filter, hence making a more uniform seal all along the surface.
Mark
'83 SC Targa - since 5/5/2001
Old 02-05-2023, 03:12 PM
Bill Douglas's Avatar
My guess is it prevents the rubber sticking to the other surface and possibly rupturing when twisted tighter.
I just put oil on because (like 930) the internet told me to.
Old 02-05-2023, 03:16 PM
rfuerst911sc's Avatar
Per a quick Google search the oil stops the gasket from distorting during install . It also helps seal and prevents the gasket to " stick " to the filter base.
Old 02-05-2023, 03:39 PM
Still Doin Time
asphaltgambler's Avatar
Yes, so as you spin the filter on and the seal contacts the surface, (without) oil it will start to drag, elongate. It takes just a smidge to make it happy......Oddly enough Ford w/ecoboost engines, they specifically state to install it dry...
Old 02-05-2023, 04:40 PM
I've always done it to prevent the relative motion of the tightening filter from grabbing the gasket and tearing it when it comes into contact with the sealing surface. I always wipe that surface as clean as I can with a rag too. Helps to verify the old gasket has been removed too.
Scott
'78 SC mit Sportomatic - Sold
Dow Corning #4
Old 02-05-2023, 08:36 PM
craigster59's Avatar
No need to oil if you're running with a Cool Collar....
Old 02-05-2023, 09:03 PM
Almost Banned Once
sc_rufctr's Avatar
This is why I've always done it. Just a dab from inside the cap when you first crack the oil bottle.
EDIT: And it's on the instructions for the oil filter.
- Peter
Old 02-05-2023, 09:10 PM
Mighty Meatlocker Turbo
Rawknees'Turbo's Avatar
Same goes for Lycoming and Continental - no lube, tightened to torque specified (aircraft oil filters have a 1" nut, with ears for safety wire around the perimeter, built into the outboard end of the filters), then wired.
Old 02-05-2023, 09:48 PM
Arizona_928's Avatar
This is when one didn't oil the filter gasket on a m1038.
Was not a fun day. Broke a 3 prong tool. Took the strap tool and hand strength.
dolor et pavor
Copyright
Old 02-06-2023, 04:48 AM
I see you
flatbutt's Avatar
I always put a schmear on the ring hoping to keep it from sticking too much. I may try the Corning schmear next time. I also fill the filter before installing so that the fill volume is closer to correct on startup. I'm goofy that way.
Old 02-06-2023, 05:05 AM
