FWIW, brake pad turned 180° /and maybe left to right. Not important on one piece pads, VERY important with holders/slide in pads.
I'm looking for a fork now. There are lots of forks on ebay but I havn't found one that is a perfect fit yet.
I'm tempted to buy one with a long enough steering tube but its for a 700c rim. I have a mill and it would be easy to machine away the 1/8" of material at the bottom of the crown to allow a 27" wheel to clear. I washed my Cannondale last night. I don't remember the last time I cleaned it. The caked on grime on the hubs needed extra attention to get off. A tooth brush and simple green was the trick. I took apart the headset and repacked the grease. The bearings and races looked perfect. The Cannondale came with Shimano 105. The old grease was chunky but still lubricated. This was the first time I had the headset apart. Shimano makes good stuff. |
Save yourself a lot of headache so you can concentrate on the training for the 100 mile ride. Aerorims are amazingly fast but that's the drawback from lack of speed. They are a deficit due to weight only because there's a bit more mass but if you go ultra light carbon wheels, weight is cut down a bit. If your plan is to go out and do this 100 mile ride within reasonable amount of time, then carbon deep dish wheel maybe a consideration if not, those Mavic rims laced to the Campy hubs will more then enough to enjoy that ride. They are light and their box shape is durable.
So I started cleaning the Cannondale yesterday. I have to wait another week for the new stem to arrive. Yesterday I repacked the headset and today I did the same for the Cannondale's front wheel. One of the cones had some pitting so those wheels should be retired. I put the axel back in with the knowledge that there is an issue with that front wheel.
I decided to repack the Campy hubs on those BMX wheels I have. Upon inspection I saw some pitting and roughness on the small end of the cone. The races in the hub looked OK. I cleaned up the old grease and repacked with fresh and placed 10 balls in one side and put the cone in without the axel to see how it rotated and it felt wrong. I suspect someone a long time ago replaced the balls with a larger diameter. I put the axel together and it felt terrible, like there is sand in the bearings. dum dee dumm....another mystery. I'm glad I caught this now before I laced up the new rims that are coming in next week. I have two other front wheels to compare ball bearings with. I have the Shimano 105 on my Cannondale and I have the Campagnolo Record on my sister's race bike. I'll make a prediction right now that the balls on the BMX wheels are .020 larger than what they should be. |
The Mavic rims come in both traditional and modern UST (tubeless ready) models. Both look the part, the profile of the UST one supports tubeless if desired the traditional doesn't.
Share with me. Teach me something I didn't know. Make me think. But don't make me a bit player in your passion play of egotism. Dueller. 13/03/09 |
I can see someone using the same bearings front and rear and not noticing the different bearing size between front and rear. |
If you can use those Campy hubs, you are golden. They are good hubs. Oil holes in the center of the hub? If not, any modern Shimano (Ultegra) hubs will close to being as good as those old Campys, that's only IMO. It takes a lot to kill them. I have tried to kill off a set of Dura-Ace wheels I built for over 7-8 years. Over hauled the a couple times. Gone through some broken spokes and a set of rims over those years. I think I still have them. Bought factory build wheels after that and never looked back. I bought Mavic wheels usually. Last edited by look 171; 03-25-2023 at 01:20 AM.. |
32 or 36 hold hubs? What are your plans? 3 cross, 4 cross for durability or you will go fancy and go 3 cross on drive side and 2 cross on none drive side? Front?
Almost Banned Once
- Peter |
https://wheelsmfg.com/ball-532-25.html Have a BB from them which is very good… easy to service and durable. Better than the equivalent Shimano one: albeit more expensive. They do answer tech questions so perhaps worth a chat. |
I want the wheels to be strong and it should simplify what spokes I need 36 holes (....I better count the holes on the campy hub, I ordered 36 on the rims) |
I've used McMaster-Carr at work a lot
https://www.mcmaster.com/products/bearings/hard-wear-resistant-52100-alloy-steel-balls-7/ Campagnolo and Shimano don't manufacture the balls, they source them from another vendor. |
3x is the typical bullet proof spoke wheel. Light but strong. It will be fun |
I tried 5/32 balls---too small. 3/16 is too big. I'm going to order 11/64 and 4.5 mm from McMaster Carr and see if one of those sizes works.
I'm really tempted to have Gilmour do the paint, maybe in a champaign white or pearl white. Just give him the frame and fork and write a check. I think the wheels I ordered are anodized black so that would give a good contrast. |
![]() March is almost done and I still don't have a bike to even train on. The new stem should be here next week so at least I can start riding the Cannondale. |
