Checked out
How does this home HVAC system work??
Can’t figure this out, my Google is weak on this one.
It’s an older system, maybe 15 years or so? I believe it’s a single system, split between the upstairs and the downstairs (so each can be controlled separately). Here’s the controls. Pictures are upstairs control, downstairs, and a third box mounted in a closet. ![]() ![]() ![]()
Checked out
The issue I’m having is sometimes the blower fan randomly goes on. It’ll run for a while, then shut off. There’s no heat or ac when it does that, just the fan.
There’s no pattern that I can tell. It seem like the way I have the levers set, the system should be “off” and not do anything. I even shut off the breaker labeled “A/C” and the blower still does its random thing. Can’t figure out if I’m doing something wrong, or there’s something broken/wrong in the system. |
The thermostat box is more than 15 years old. My family home had one 40 yrs ago. The closet box may be a newer communicator - I would think the T-stats would be out of the loop.
My Honeywell wi-fi T-stats do turn on the blower for 'recirculation' 35% of the time and at a lower blower speed - uses little relative enrgy and balances out the room temperatures. Fan settings are Auto - ON - and Circ etc. The AV breaker will only cut out your outdoor AC condenser unit. The furnace fan is powered by 120V and located separately. I am glad to answer early - none of what I said is wrong but won't be an helpful as others!
75 911S Targa - Mine from 2001 until sold to Germany buyer 10/2016 <ALL DIY> Brakes/Wheels '01, Body/paint/restoration 7/04, Suspension 3/07 Engine rebuild - done 7/08 - added 28 tube cooler and SSIs - running strong. Ducktail painted. 2021 MachE, 2012 Outback, 2019 Crosstrek, 2018 Impreza wagon |
UnRegistered User
It looks like the Trolatemp Total Zone is a sharing system and should have a damper to direct air to two different zones.
I found the manual online and will try to find it through the honeywell site when I get to work. Those Chronotherm stats were available when I was doing commercial work over 30 years ago...
Bill K. "I started out with nothin and I still got most of it left...." 83 911 SC Guards Red (now gone) And I sold a bunch of parts I hadn't installed yet. |
