jyl jyl is online now
jyl's Avatar
Bulge in Wall
My wife is painting the stairwell from first to second floor, and noticed the wall above the landing is bulged out about 1”. I got called to figure out if there’s a problem.
The bulged or unstraight part of the wall is about 5’ from top to bottom. The center of the bulge is at the second floor sill level, where the joists and sill and etc would be, and on the other side of that wall is the bathroom and specifically the toilet. So my wife wonders if we have a water leak that is damaging the wall.
I should mention, I have no idea if this bulge is new or has been here the whole time we’ve lived here. This part of the wall is always covered by the stairwell door, which we leave open. I doing think I’ve ever touched this part of the wall, or looked closely at it, in the last 16 years of living here.
This is what I did to investigate.
1. The wall surface (lath and plaster) feels firm, solid, dry.
2. I drilled a couple of holes into the wall at the center of the bulge, the material in the holes is dry.
3. The structure under the landing, at that wall and directly under the bulged place, happens to be exposed (I had pulled off the ceiling board when installing some ducts) and it’s dry.
4. The toilet drain is not in that wall - the drain stack is in the adjacent wall. The toilet supply line is probably in that wall.
My logic is that for a water leak sufficient to swell or deform or damage the structure of the floor, enough to bulge the floorplate (joists, sill, subfloor) laterally - well, it would be a large amount of water for a long time, if it’s even possible. That much of a leak would be visible somewhere - actively dripping probably. The ceiling below should be dripping. So my conclusion is maybe there was a huge water issue once, or maybe the house is just very not-straight in this spot, or something weird happened between 1911 and 2006, but I don’t think there is anything currently going on.
Agree/disagree? What else should I check?
Old 04-27-2023, 07:56 PM
For mold.
Old 04-27-2023, 08:12 PM
LWJ LWJ is online now
It’s dry. Move on. Old houses have weird stuff. I had a house in NE Portland that bled from the walls once. No biggie.
Old 04-27-2023, 08:23 PM
Almost Banned Once
sc_rufctr's Avatar
Did you call a priest?
- Peter
Old 04-27-2023, 08:27 PM
Monkey+Football
Icemaster's Avatar
Send a message via AIM to Icemaster
Plaster can still let go of lath. Could be the guys were on top of the ladder and didn't force as much wet plaster through the gaps to create a large enough key. Stuff gets old, not everything lasts forever.
If there was even a slow leak from somewhere you'd still see some staining on the wall where the stuff was leaching through.
'Move on' would get my vote.
<Insert witty comment>
85 Targa Wong Chip Fabspeed M&K Bilsteins and a bunch of other stuff.
Old 04-27-2023, 09:14 PM
FUSHIGI
Cumulative effects of toilet feed line condensation especially if toilet has heavy use and/or malfunction at some point in the past?
Cults require delusions.
Old 04-28-2023, 02:13 AM
Born to Lose, Live to Win
ramonesfreak's Avatar
I would use one of the drilled holes to stick my automotive borescope through and see if anything is visible and probably move on to one of my thousand other house projects
Things fall apart; the center cannot hold…
1983 911sc
2025 Chevy Colorado ZR2
Old 04-28-2023, 04:13 AM
Sounds to me like there may have been a problem a long time ago, but probably hasn't been a problem in a long time. I'd move on.
Old 04-28-2023, 05:06 AM
Vaccinated and Boosted
mgatepi's Avatar
120 year old farm house here. Our stairwell outer wall is 18 feet tall, has 3 distinct bulges. Never any water issue, no water lines or drain pipes, just bulges...... just paint and forget.
We call it character!
2013 911 Turbo S
2025 Lexus TX350, 2024 Honda CRV Hybrid
1930 Cadillac V8, 1991 Ford F250,
2023 Chevy Colorado
And some garage space....
Old 04-28-2023, 05:12 AM
Evil Genius
Rusty Heap's Avatar
You guys flushing your Viagra down the drain in your pee?
Life is a big ocean to swim in.
Wag more, bark less.
Old 04-28-2023, 05:15 AM
The house demons are trying to escape .... nuthin' to worry about .... next!
Old 04-28-2023, 05:38 AM
I wonder if his house looks like this.
Old 04-28-2023, 07:57 AM
What?!?!
DonDavis's Avatar
Easiest question we've had on the board in a while...
"dude, it's spiders, lots of spiders"
running shoes, couple tools, fishing pole
1996 Subaru Legacy Outback AWD, 5speed
2002 Subaru Impreza WRX, 5speed
2014 Tundra SR5, 4x4
1964 Land Rover SII A 109 - sold this albatross
Old 04-28-2023, 09:07 AM
jyl's Avatar
I going to ignore it.
So much house expense coming this year: exterior paint, window replacement, kitchen cabinets+floor. The stairwell wall will just have to stay bulgy.
Old 04-28-2023, 09:12 AM
What?!?!
DonDavis's Avatar
...don't forget spider eradication
Old 04-28-2023, 09:18 AM
Model Citizen
herr_oberst's Avatar
That's become my whole approach to lots of things these days.
I expect a reckoning, I hope it's not overwhelming.
Old 04-28-2023, 10:31 AM
Old 04-28-2023, 12:14 PM
