-   -   Daily Driver Help Needed (Jetta) (http://forums.pelicanparts.com/off-topic-discussions/114046-daily-driver-help-needed-jetta.html)
JR Indy 06-08-2003 02:08 PM
My daily driver - 96 Jetta with 2.0L engine is not starting-no fuel, no spark from my testing, but it does crank. Any help appreciated, even if pointed to good bb. VWVortex isn't doing it.
bell 06-08-2003 02:35 PM
disconnect the battery for about 5 minutes......this will reset the computer.......worth a shot.
also does that car have a "rollover" cutout for the fuel? if it does it may need reset, check your owners manual for where the reset button is.
JR Indy 06-08-2003 05:08 PM
Bell,
I've disconnected the battery to reset ECU already, no luck. Rollover detection is not an option on the vehicle.
It does seem like the imobilizer function though with no fuel and no spark. Searching for bad wiring at the moment.
nostatic 06-08-2003 05:57 PM
ummm...use the '86 as your daily driver. Problem solved.
JR Indy 06-08-2003 06:43 PM
Too many miles driven daily, plus the midwest weather kind of keeps me from using the '86 as the daily driver. Thanks for the help though.
island911 06-08-2003 07:09 PM
"no fuel, no spark . . ."
Sounds like an ingnition side problem. (I'm fairly certain that the fuel pump will not run unless the hall sensor (distributor) gives x-number of pusles per second.)
JR Indy 06-09-2003 07:49 AM
The Hall Sensor is the next item to check. You're right, it is part of the distributor assembly on this vehicle.
island911 06-09-2003 08:28 AM
I have had the wiring to the hall sensor fail on one of these. I vaguely remember it being a broken wire (at the solder joint) under the hall sensor.
Anyway, the quick check is to see if voltage is getting to the sensor. . ..something like ~3V.
JR Indy 06-09-2003 12:06 PM
Island,
I'm at work and don't remember if this is a three wire device or not. If so, isn't it the middle terminal that provides the output?
I will do some testing tonight when I get home.
island911 06-09-2003 12:43 PM
Well I'll preface things by saying I'm going off a decade old brain-cells on this.
Anyway, I'll sugest you test the input. . . being that the voltage output, from the hall effect is minimal (measuring induced electron drift)
The Bentley shop manual should tell you which pins should be tested for voltage.
Or, just simply remove the dist' plate that carries the hall sensor, and look at the bottom side for broken wires.
JR Indy 06-10-2003 06:37 PM
Finally got some time to debug, and to make nostatic happy I've been driving the 86 daily.
Brought home the diagnostic tool from work, fault code P1340 which is cam / crank sensor sequence problem of some sort. Cam sensor (Hall Sensor) signal looks good on scope. With the sensor disconnected, results in the same fault code. Must be wiring problem between sensor and ECU. More searching tomorrow, another excuse to drive the 86.
trj911 06-12-2003 05:43 AM
Hey John,
Do you still need a track pass for USGP Fan Appreciation Day this Sunday? I have an extra one if you do. Just meet us at the Big Lots parking lot on 30th street between 9:15 and 9:30 AM on Sunday. We'll head over to the track as a group at 10:15.
Tom
JR Indy 06-12-2003 11:24 AM
Tom,
Yes I do, I had troubles sending e-mails to you, thought your account must have changed. What else do I need to bring?
trj911 06-13-2003 05:13 AM
Try my work email Tom_jacobson@natcity.com
Just bring your car and yourself. I will be coming with my brother and my 2 boys.
Here is the email I got from the track. See you Sunday!
This email is to confirm that your RSVP has been received for the June 15th USGP Customer Appreciation event. Remember, you are only required to have one ticket per vehicle. Also, please be sure to sign the waiver on the back of the ticket prior to entering the facility.
In addition, we would like to make you aware that we are launching our inaugural Indianapolis Motor Speedway email newsletter early next month. The newsletter will feature insightful stories about our three distinct events at the Indianapolis Motor Speedway, as well as highlight special offers and promotions throughout the year. To make sure you receive the monthly newsletter click on the link, http://ims.brickyard.com/ims/club/cust_survey.php, and fill out the proper information.
Once again, we look forward to seeing you on Sunday June 15th.
