			Are you talking about replacing both with new?  I would do both just for the peace of mind, you take this boat out a good distance.
				If so can you sell the one running one off to offset some of the cost?  |
			Also how about those guys/gals with 5 of those 500hp outboards on the back!
This. For offshore work, I want two reliable units.
	Greg Lepore 85 Targa 05 Ducati 749s (wrecked, stupidly) 2000 K1200rs (gone, due to above) 05 ST3s (unfinished business)  |
 Still waiting for a couple of quotes. And trying to do some research to help with deciding which brand to go with.
	2000 Boxster S (gone) 1972 911s Targa (sold) 1971 911t coupe roller (sold) 1973 911t coupe / 3.2 (sold) Gruppe B #057  |
 I’m guessing it would be Yamaha. Sent from my iPhone using Tapatalk  |
			 Parrothead member
			Just went through the same exact thing with mine. Took water in my two lower cylinders on my port side Yamaha 200s. Motors are mid 90 2 strokes.  Was super pissed because of how good they ran.
			Just replaced them with a set of used 2006 200HPDI Yamahas. Scored a real good deal on them. Low hours, seemed to be well maintained. I just rigged one this weekend, hopefully get the other on tomorrow. .
	Vinny Red '86 944, 05 Ford Super Duty Dually '02 Ram 3500 Diesel 4x4 Dually, '07Jeep Wrangler '62 Mercury Meteor '90 Harley 1200 XL "Live your Life in such a way that the Westboro Baptist Church will want to picket your funeral."  |
			 Model Citizen
Honest question, if the engine in question was roached after only 575 hours, how can we assume that the new ones will have 3 to 4 times the service life?
	"I would be a tone-deaf heathen if I didn't call the engine astounding. If it had been invented solely to make noise, there would be shrines to it in Rome"  |
			 Navin Johnson
 It's a crap shoot how the engines were maintained by prior owners.. I grew up around boats, and learned from my father (lifelong Boater) how critical regular maintenance is. Though I'm currently boatless.. My last boat was a 21' Grady C/C with a Yamaha 200HP two stroke. Aftermost uses when I got back to the dock, I'd tilt the engine up fit the clamshells, and fresh water flush the cooling system.. Every off season I would: Change the plugs, Change the impeller Change the gear oil in the lower case. Fog the engine before storage.. Full tank with Stabil.. so no condensate in the fuel.. So many boats are used hard and put away wet.
	Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others  |
 I’ve put 80 hours on the engines this year, so I imagine I’ll put 100-150 hours a year on the new engines. And believe me ill be flushing the engines after every use, I do now. And keeping up with the maintenance. I pretty much do everything now except changing the impellers, kind of hard to pull the lower units while it’s on a lift. But I’m going to look into that.
			600hrs is pretty low, sort of the equivalent of 36000miles on a motorcycle engine. Was the $15k rebuild price for the entire unit or just engine? How did water get in the cylinder?
	87 930,  |
 Rebuild is just for the power head.
			 Counterclockwise?
			My 200HP Merc blew up because there was water in the gas.
			It happens.
	Rod 1986 Carrera 2001 996TT A bunch of stuff with spark plugs  |
			 Platinum Member
 Any idea how much a lower unit weighs? What is your cruise RPM? I have 2 friends that strongly suggest I keep it under 4300 RPM for longevity. Perhaps PO kept the revs up?
			Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams Last edited by dad911; 06-22-2023 at 09:00 AM..  |
			 Better in Person
			Have you considered having the failed motor tore down to see what the problem was?  may give you some insight into what could be done to the remaining motor to shore it up while rebuilding the failed one.
			EDIT: My buddy has two offshore fishing boats and he hates his I/O one because the motor compartment takes up so much room in the fishing deck area.
			78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft Last edited by juanbenae; 06-22-2023 at 09:06 AM..  |
			 Counterclockwise?
I believe you need to be in the highest RPM's for the health of a motor. Prop selection with dictate WOT RPM's. Outboards do not like to be lugged.
			 Navin Johnson
 On the Yamaha, there are 7 bolts that bolt the unit to the powerhead. 6 are obvious, one is accessible after you remove the anode.. If your boat is in a lift it would be easy enough to get a dinghy and drop it into the dinghy then get the unit ashore and swap the impeller.. An hour job at most.
			 Counterclockwise?
			I can't see doing this in a dinghy. Getting it off maybe. Putting it back in it can be a real bear. You push up. Dinghy goes down.
			 Navin Johnson
			It goes back pretty easily... or use bolts to draw them together..
			 Parrothead member
			Ive pulled a lower off. with the motor tilted up with the boat in my dock.  Not really hard to do. Think the lower is around 50lbs.
			What were you doing when the engine failed? Steady cruse at 4000rpm or did you happen to go from wide open to idle quickly?
	87 930,  |
