Boat forums?
Because I don't have enough pain and/or projects in my life I am looking at buying a 1987 Sea Ray Sorento boat as my next project. I anyone has ever worked on, restored or maintained an older boat, any advice (besides don't buy it) would be greatly appreciated.
1982 SC
Old 07-14-2023, 05:56 PM
Parrothead member
VINMAN's Avatar
Unfortunately way too much experience with boats...
Probably the best boating forum out there is https://www.thehulltruth.com/
For Sea Ray specific you have Club Sea Ray
Vinny
Old 07-14-2023, 06:40 PM
HobieMarty's Avatar
There is a boat forum called Fiberglassics that I am on from time to time. It mainly deals in fiberglass boats from the 50s, 60s, 70s, and 80s. We have a 1962 Span America runabout in the boathouse at the cabin, it was my Pawpaw's boat and that is why I joined that forum many years ago.
Wonka
Old 07-14-2023, 09:52 PM
MAGA
Tim Hancock's Avatar
I was on this forum which is pretty active for doing the kind of work you will likely need to do.
https://forums.iboats.com/forum/boat-restoration-building-and-hull-repair.40/
Here is my thread I started on that forum a few years ago. My boat was a lot of work due to having to replace stringers, bulkheads and floor. Boat manufacturers until the late 90's or so mostly used plywood for stringers/bulkheads and floors but they only coated and tabbed them using regular fiberglass resin. Fiberglass resin does not waterproof wood long term so you get rotting. I rebuilt mine with new plywood and tabbing using epoxy. I also used epoxy for all screw locations into the wood. My boat is now better than new structurally speaking. It legally holds 13 people so with grandkids we will keep it for a long time so it was worth it to me. It came out great and we still use it often.
https://forums.iboats.com/threads/1995-larson-214-lxi-floor-and-stringers.702533/
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne
0% Liberal
Men do not quit playing because they get old.... They get old because they quit playing.
Old 07-17-2023, 06:07 AM
Well at least you’re looking at a halfway decent brand, built pretty well compared to a lot of others.
Boats are sort of like hot tubs great when you first get them and after awhile the novelty wears off, they break and your just not interested in fixing them.
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind.
Old 07-17-2023, 09:45 AM
Seahawk's Avatar
Tim, you missed a few things I would correct immediately.
I don't know what it is you do in the real world, but I bet you don't suck at it.
BTW, why are boats right hand drive?
1996 FJ80.
Old 07-17-2023, 10:00 AM
MAGA
I am not as good as I once was....
My day job since '91 has been special machine designer/engineer.... However I am happiest when I am trying to figure out how best to fix, build or restore something in my home shop. Cheapskate at heart so have always bought cheap/used/broken then enjoy the challenge of fixing.
0% Liberal
Old 07-17-2023, 10:16 AM
Seahawk's Avatar
We will (the collective "we") be the judge
Honestly, I have had a few occasions working on equipment on the farm where I have a WWTD moment: Do it quick or do it the Tim way.
I always choose "quick" but at least I think about it
1996 FJ80.
Old 07-17-2023, 10:39 AM
Non Compos Mentis
Most common theory is from back in the rowing days, steering was accomplished with a big oar over the side.
Since most people are right-handed, the guy steering was on the right side.
Also why boats approaching head-on, the rule is to pass port-to-port.
This way, the steering oars were on the starboard side, not where they would bump into each other.
(just looked this up a couple days ago after my wife asked)
Old 07-17-2023, 01:02 PM
Navin Johnson
TimT's Avatar
I think another reason is with single screw boats, the screw typically turns clockwise...so the starboard side has a tendency to raise...the weight of the pilot help... counter that effect..
'69 911 GT-5
'75 914 GT-3
and others
Old 07-17-2023, 01:16 PM
Friend of Warren
I to have a SeaRay open bow. The two places I frequent most our Club SeaRay and iboats. Both links listed above.
Kurt V
Old 07-17-2023, 06:19 PM
Jeff Alton's Avatar
The stringers/bulkheads I hope were totally encapsulated and sealed before the floor went down.
Cheers
www.turn3autosport.com
Old 07-17-2023, 06:20 PM
Thanks everyone.
The boat was bought out from under me. I guess it was in much better shape than we thought as the first person that saw it bought it and left with it. Got there before me and it was gone
1982 SC
Old 07-17-2023, 07:37 PM
Oh, that's too bad...
P.S. I'm still driving your brother's 89 cab...
Old 07-18-2023, 10:28 AM
Counterclockwise?
I always thought it was because everyone stayed to the right and this would be the only way for the driver to hold on to the dock/pier/lock etc..
Rod
1986 Carrera
2001 996TT
Old 07-18-2023, 01:52 PM
