-   -   GFCI Question (http://forums.pelicanparts.com/off-topic-discussions/1143585-gfci-question.html)
1990C4S 07-24-2023 08:13 AM
Originally Posted by look 171 (Post 12051003)
Op mentioned downstream outlet has no power not up.
I was replying to Steve's scenario. And the OP's scenario: if downstream outlets are dead and the GFCI outlet is live, that is not a GFCI issue, unless the GFCI has failed internally.
Rtrorkt 07-24-2023 12:47 PM
Originally Posted by masraum (Post 12050561)
THey are awesome. Klein $19
https://www.homedepot.com/p/Klein-Tools-Non-Contact-Voltage-Tester-Pen-50-1000V-AC-NCVT1PR/317460355
or
https://www.amazon.com/Non-Contact-Detector-Klein-Tools-NCVT1P/dp/B099SJ6469/
https://images.thdstatic.com/product...t5a-64_600.jpg
These are also a must have, IMO. You can confirm outlet wiring and they'll test a GFCI. And I think they are supposed to be a better test than the button on the GFCI, but I don't remember exactly what I read.
https://i5.walmartimages.com/asr/bb8...8&odnBg=FFFFFF
Thanks to all who have weighed in. I have called in an expert so we will see what he says. Using my tester on the GFCI outlet it tests green or all ok. Mystery. When expert sparky figures it out I will post the solution
1990C4S 07-24-2023 12:51 PM
I think you did the right thing. The root cause of what you're experiencing is probably going to need more expertise than you have.
There's a time to try on your own, and a time to get help.
