-   -   CAN bus tech...educate me (http://forums.pelicanparts.com/off-topic-discussions/1143766-can-bus-tech-educate-me.html)
flatbutt 07-25-2023 08:03 PM
So, my new to me Harley uses the CAN bus protocols. I want to mount an accessory fuse block to the bike. If I power the fuse block directly from the battery will it interfere with the CAN bus in any way?
asphaltgambler 07-26-2023 01:41 AM
No because you're talking about 2 separate things. Direct battery circuit VS low voltage network communications.
flatbutt 07-26-2023 04:59 AM
Thanks!
asphaltgambler 07-26-2023 05:18 AM
You can also tap into the keyed 'on' circuit from the ignition switch, if you need switched power instead.
