I see you
CAN bus tech...educate me
So, my new to me Harley uses the CAN bus protocols. I want to mount an accessory fuse block to the bike. If I power the fuse block directly from the battery will it interfere with the CAN bus in any way?
Si non potes inimicum tuum vincere, habeas eum amicum and ride a big blue trike. "'Bipartisan' usually means that a larger-than-usual deception is being carried out." |
Still Doin Time
No because you're talking about 2 separate things. Direct battery circuit VS low voltage network communications.
'15 Dodge - 'Dango R/T Hauls groceries and Kinda Hauls *ss '07 Jeep SRT-8 - Hauls groceries and Hauls *ss Sold '85 Guards Red Targa - Almost finished after 17 years '95 Road King w/117ci - No time to ride, see above '77 Sportster Pro-Street Drag Bike w/93ci - Sold |
I see you
Thanks!
Still Doin Time
You can also tap into the keyed 'on' circuit from the ignition switch, if you need switched power instead.
