-   -   Detached Garage Foundation Issues.... Fix or...? (http://forums.pelicanparts.com/off-topic-discussions/1144085-detached-garage-foundation-issues-fix.html)
Arizona_928 08-05-2023 12:11 PM
That looks exciting.
Did they not put a sealer on the outside?
A930Rocket 08-05-2023 01:12 PM
You don’t want very wet concrete, as that will weaken the psi mixture. After the footer is raised, talk to a concrete company or somebody that pumps concrete with a 2 inch line about what specific grout mix to use.
ltusler 08-06-2023 09:18 AM
Yes, its sealed, drain tiled and a dimpled membrane.
Yes they pumped it in with a 2" hose.
Arizona_928 08-08-2023 06:31 AM
Thanks for the help Rod, Rocket, Scott, Bill and Zeke!
Originally Posted by ltusler (Post 12060991)
See if there is a basement repair company in your area that will jack it back in place support it, install rebar in the block voids then pump in very wet concrete. Just had this done at out lake place. the lakeside wall had 1.5" of deflection.http://forums.pelicanparts.com/uploa...1691260699.jpg
Do you have any more pictures of the process? I find that very interesting for some reason.
