That looks exciting.
Did they not put a sealer on the outside?
dolor et pavor Copyright |
You don’t want very wet concrete, as that will weaken the psi mixture. After the footer is raised, talk to a concrete company or somebody that pumps concrete with a 2 inch line about what specific grout mix to use.
Yes, its sealed, drain tiled and a dimpled membrane.
Yes they pumped it in with a 2" hose. |
Thanks for the help Rod, Rocket, Scott, Bill and Zeke!
Do you have any more pictures of the process? I find that very interesting for some reason.
