What's that smell??
I have a 40gal electric water heater in my basement and there is a distinct smell coming from it in the last few days. (it's almost a sulfur smell)
It's prob at least 15 years old and has never been any trouble.
All the water that it heats has gone through my water softener first.
Should I just ignore it? Or, replace it?
78 SC Targa Black....gone
84 Carrera Targa White
98 Honda Prelude
22 Honda Civic SI
Old 08-12-2023, 01:59 PM
I think the avg usable lifespan of a water heater is 8-10 years. Since you have a softener, you shouldn't have much build up. I'm not sure what, if anything that would do to the life of the anode (or is it a cathode) inside. I would assume that soft water would extend the life of a water heater, but that's just a guess on my part.
Are you on city water or well water?
Old 08-12-2023, 02:37 PM
Well water.
A friend (who was just guessing) also said it's prob the anode rod. I'm wondering if it is possible to replace one this old. It looks clean at the outer connection...but the threads may be a different story.
Also...are all anode rods similar? Or do I have to get one specific to my heater?
98 Honda Prelude
22 Honda Civic SI
Old 08-12-2023, 02:43 PM
Well water.
A sulfur/rotten egg smell is not uncommon with well water.
This link has several things for you to think about, and a little troubleshooting flow chart to help identify the issue.
https://www.health.state.mn.us/communities/environment/water/wells/waterquality/hydrosulfide.html
I believe most anodes are fairly easily replaced and all about the same. It is a rod the length of the water heater, so it could be several feet long which can make removal an issue if you don't have several feet of clearance, but I have heard/seen that there are anodes that are designed for limited space. They are essentially segmented.
Old 08-12-2023, 02:50 PM
^^^ Thanks.
The very first step in the flow chart from the link, said it's the water heater. Then my question is...why don't I notice that smell when using the shower?
I will prob see if I can loosen that nut on the top without damaging anything else and replace the rod. I have enough clearance above.
98 Honda Prelude
22 Honda Civic SI
Old 08-12-2023, 02:59 PM
pwd72s's Avatar
Hope you have a big socket and a long breaker bar...and better have a replacement in hand before loosening.
Old 08-12-2023, 03:13 PM
^^^ Yeah...I'm figuring I'll have to remove the inlet and outlet water lines and prob lay the heater on it's side just to remove the nut. (and the electrical 220 line)
Not looking forward to it.
98 Honda Prelude
22 Honda Civic SI
Old 08-12-2023, 03:18 PM
I have several sections of pipe that I slip over my short breaker bar.... in 2, 3, and 5'. A 5' bar extension gives ya a LOT of leverage
Old 08-12-2023, 03:24 PM
^^^ I'll have no problem with that part...it's the holding onto the round pig of a heater to keep it from turning.
98 Honda Prelude
22 Honda Civic SI
Old 08-12-2023, 03:28 PM
Super Moderator
cstreit's Avatar
ANode rod.
Being on a well I upgraded to an electric one... Works really well and really reduced sulfer smell in the water.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 08-12-2023, 03:29 PM
Originally Posted by cstreit View Post
ANode rod.
But I smell nothing in the hot or cold water. The smell is only noticeable when getting near the water heater. 8-10 feet away...it's not noticeable.
98 Honda Prelude
22 Honda Civic SI
Old 08-12-2023, 03:32 PM
pwd72s's Avatar
Some tips here..only I'd add..use a breaker bar, save the ratchet?
Old 08-12-2023, 03:37 PM
^^^ Good video...thanks!
I'm sure that if I need to...I can put a bar between the inlet and outlet fitting for keeping the tub from turning.
If there is a will...there is a way.
I have a long breaker bar for the nut that will do the trick..(maybe with a pipe added.)
98 Honda Prelude
22 Honda Civic SI
Old 08-12-2023, 03:48 PM
pwd72s's Avatar
And another video...breaker bar didn't work for this guy...who also smelled rotten egg...but hey, he got to buy a tool!
(edit) Never heard of the "coro protector" he used. Curious if anybody else here has used one? Maybe that's what Chris
meant when he said he upgraded to an electric one?
Old 08-12-2023, 03:52 PM
^^^ Hah...wasn't much left of his anode rod.
Here again though...I don't smell anything in the hot or cold water. It's only when walking near the water heater. I'm wondering if I'm not chasing the right problem.
98 Honda Prelude
22 Honda Civic SI
Old 08-12-2023, 04:04 PM
I see you
flatbutt's Avatar
a sulfur/rotten egg smell is not uncommon with well water.
i believe most anodes are fairly easily replaced and all about the same. It is a rod the length of the water heater, so it could be several feet long which can make removal an issue if you don't have several feet of clearance, but i have heard/seen that there are anodes that are designed for limited space. They are essentially segmented.
btdt
Old 08-12-2023, 04:14 PM
btdt
When yours went bad....did you smell it in the water?
Mine smells perfect...the smell is coming from the heater itself.
98 Honda Prelude
22 Honda Civic SI
Old 08-12-2023, 04:17 PM
I see you
flatbutt's Avatar
It was in the shower that I smelled it. That's when I went to the tankless heater.
Old 08-12-2023, 04:19 PM
Thanks...that makes me think all the more that it's not my anode rod.
I have not noticed any smell in the shower or drinking water...both have been normal.
And I know my smeller is good...
My doctor said she has never seen a patient with a better smeller.
98 Honda Prelude
22 Honda Civic SI
Old 08-12-2023, 04:26 PM
Make Bruins Great Again
Por_sha911's Avatar
Just a guess: Assuming that you have an electric water heater (gas has that rotten egg smell). At 15 years old, your tank may be beginning to leak and there isn't enough leakage to see water at the bottom. The smell could be the water collecting in the jacket insulation. Have you flushed the unit annually?
I would suggest just going ahead and replacing the unit before you possibly find yourself with a flood.
Joe
Old 08-12-2023, 04:28 PM
