I see you
How to NEATLY drill fiberglass
I want to mount a luggage rack on my trike and must drill thru the fiberglass trunk lid. I've never worked fiberglass before. So, first what type of bit should I use? Second...anything else I should keep in mind?
tia
Si non potes inimicum tuum vincere, habeas eum amicum and ride a big blue trike. "'Bipartisan' usually means that a larger-than-usual deception is being carried out." |
Put a piece of masking tape over the spot and then drill it. Go very slow so you don't blow out the hole on the backside.
Jacksonville. Florida https://www.flickr.com/photos/ury914/ |
Brad point drill bit. How big is the hole? If blowout is a concern, drill half way from top, go under and drill from underneath. Basically score the hold from the bottom, finish drilling through from top all with the same bit.
Make Bruins Great Again
Start with a small pilot hole. Be sure to not let the fiberglass flex by putting a block of wood on the opposite side so for support. Go slow with very little pressure and let the bit do the work.
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
I see you
Thanks guys. A brad point wood bit it is.
Control Group
Wow, that was fast
She was the kindest person I ever met |
I see you
People like to help an old guy like me.
I would try to sandwich the fiberglass between two pieces of wood, clamp them, then drill.
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." |
Also drill it smaller than needs to be and work it larger with a fine file.
Counterclockwise?
Hold the drill tight so it does not skate across the finish.
A buddy of mine did this when drilling holes for speakers in his jet ski. The only time I have ever seen him cry. lol
Rod 1986 Carrera 2001 996TT A bunch of stuff with spark plugs |
Control Group
Does the mount for the rack have something to go behind the fiberglass to stiffen it, spread the load, so to speak.
The pictures are not coming up on my computer ![]() Do you put resin on it to seal up the hole, like painting a hole in metal?
Two flute drill bits will always tear the fiberglass. Pilot drill is fine, rotary file , dremel , die grinder is the tool to use to enlarge the hole. A hand file still can fracture the edges.
I see you
After drilling seal the exposed fiberglass with some clear nail polish.
I see you
3/8"
DeWalt 3/8 brad point bit from Amazon for only a few bucks.
Too small for the method we used. We had to drill 1/2" holes for fiberglass trailer covers. We used a 1/2" hole saw, ran it backwards until we got through the gel coat, then ran it forwards slowly to get through the fiberglass. I don't think they make 3/8" hole saws. Even with a brad point bit I would drill forward until the flutes just touched the gel coat. Then run it backwards to get through the gel coat without chipping it. The big problem you face with trying to do it neatly is that the gel coat chips easily. The drill flutes cut into the surface and lift it up. Getting under the gel coat and pulling it up will causing it to chip. Cutting through the gel coat will cause a ragged hole, you need to abrade it.
. Last edited by wdfifteen; 09-01-2023 at 07:05 AM.. |
