Little Heet will help.
https://knowhow.napaonline.com/what-is-gas-line-antifreeze-and-why-do-you-need-it/
1996 FJ80. |
Start looking for a walk-behind snow thrower...if you don't already have one.
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI |
Go to Thiesen's, Fleet Farm or Farm and Fleet, and buy a steel snow shovel. Don't try to get by with a cheap plastic one. Don't go to Menards.
Shovel the snow before the rest of the family has a chance to stomp all over it and turn it to ice. This includes driving on it. It will come up much easier. If you are away during the day and it snows, park in the street, shovel a path for your car, then put it in the garage. When you say mid-Iowa, I'm assuming no further north than I-80. You shouldn't get that much snow, a small snow blower or thrower is likely adequate for most snowfalls. My step-daughter lives in Davenport, we bought her a 7hp 26" wide snowblower. She's never used it. |
I find that when I drive in the snow I will drift/slide/test traction the entire time I am driving. 1. It entertains me and 2. I always know where the limits are. I wasn’t completely aware of this and had a shocker realization. But it makes sense. I am a skier and you need to know what the surface offers so that you can perform the best.
Enjoy! (Also, get a SAD lamp if needed) |
You escaped too? I forget which Kevin are you, from around the Pasadena area or the Kevin with the P car bodyshop? Coming form S cal, that snow looks exciting to spend the winter.
1.367m later
Slightly north of the 80 in Carroll County (the 71 and the 30).
non velox ad propitiare, verisimile non oblivisci If it's not The Original Automotive Innovations and Restoration, then it's just hot AIR. Last edited by KevinP73; 11-26-2023 at 04:16 PM.. |
If it's yellow do not eat it.
1970 911T XR400 93 F150 |
Just remember, your antilock brakes may or may not save you, on ice if you are going too fast brace for the impact in a tight spot. You hear the chatter of the brakes while you don't seem to be going any slower. The best tires in the world can't make ice like dry pavement. Even in wet snow it can get you. Watch your following distance.
Also, watch for icy spots on walks and steps, sneaky little hazards that can get you. |
Cars and Cappuccino
SoCal to Iowa? That sounds interesting. Was born in Iowa and left the Midwest in the 90's. Anyway, snow is not nearly as bad as ice. Wind can actually contribute to the creation of ice on roads. If you think you are going to be driving at night I'd carry some road flares and extra hat and gloves in the car. If you will really be parked outside overnight you might want to install an electric block/oil pan heater. See this story.
https://www.thedrive.com/maintenance-repair/36647/engine-block-heater
http://www.carsandcappuccino.com 1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits 1985 Prussian Blau M491 Targa 1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe 1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday) |
1.367m later
Noted. Thanks
non velox ad propitiare, verisimile non oblivisci If it's not The Original Automotive Innovations and Restoration, then it's just hot AIR. |
One thing I've picked up over the years is that bridges will freeze before roads on the ground will.
Something to do with the cold air being on both sides of the pavement on a bridge. Good luck! First time I was in snow as an adult I didn't even recognize that it was snowing, I thought some trees were shedding their flower petals.
Scott '78 SC mit Sportomatic - Sold |
I see you
Oh then there's what we call black ice. It is a coating of clear ice that is completely transparent and so looks black like the road surface. It will fool you and do it's best to kill you. AMHIK
Si non potes inimicum tuum vincere, habeas eum amicum and ride a big blue trike. "'Bipartisan' usually means that a larger-than-usual deception is being carried out." |
Awesome!!
Not far from Ames where I went to school. I have driven through there even on 30, back in the early 90’s. My family is all originally from Iowa and if I was a betting man I would say my son goes to Iowa State next year. |
dolor et pavor Copyright |
Tires with as many sipes/grooves as possible.
Remote start installed Fix any windshield chips as they turn into cracks during the freeze - hot defrost- freeze cycle Upgraded headlight bulbs Winter weight motor oill There will be lots of red light runners. Don’t jackrabbit out the instant it’s green Be courteous of those that are more comfortable driving on ice and snow and let them go by |
LOL, reminded me of this
Do not pay too close attention to the local weather. Snowfall is not necessarily fatal. Regardless of their warnings, you do not have to hide in the basement when a 10% chance of snowfall is forecast.
