pwd72s's Avatar
Tool: Shake n' Break
Need air to use one, evidently...
https://www.youtube.com/watch?v=Pwz-NXj5ZIk&ab_channel=EricTheCarGuy
Old 02-14-2024, 06:52 PM
wdfifteen's Avatar
Nissan uses Philips head screws?
I wonder if they're really JIS and I wonder if the tool bits that come with that are Phillips or JIS.
Old 02-14-2024, 07:02 PM
pwd72s's Avatar
Good question...
Old 02-14-2024, 09:04 PM
Kantry Member
oldE's Avatar
So......if you don't have an air hammer, just get your impact driver out of your toolbox.
Best
Les
Best
Les
Old 02-15-2024, 12:08 PM
Zeke's Avatar
I would think you will have a good chance of breaking a screw with that. I've had a manual impact driver since the motorcycle days of my youth. You know those side cover screws, don't you.
And you didn't want to booger them up either. I'll stick with heat and the simple tool.
However, that tool is based on something I think we've all done. Crescent wrench on a square shaft screwdriver in one hand and a hammer in the other. At least he's not beating on his screwdrivers. So thumbs up overall.
Old 02-15-2024, 12:30 PM
Friend of Warren
I’ve always just used my battery powered 3/8 inch impact wrench with the appropriate size socket that a screw bit can fit into. I just lean into it to make sure it the bit stays in the slot.
Kurt V
Old 02-15-2024, 01:42 PM
