				Retirement Project - 996
			Last week, I was called by a longtime friend who told me about an opportunity to purchase a 1999 996 C4 for a great price.  The car had been parked in his neighbor's garage under a cover for the past 12 years.  His neighbor has sold the home and wanted to quickly sell the Porsche.  I contacted him, inspected the 996, and had it transported to my home.  The tires were flat, but held air to roll it around.  Of course the battery was completely dead as well.
				The body and paint are in excellent shape. The interior has minimal wear and looks fantastic. The car comes with minimal records and I don't know if the IMS has been addressed. I ordered a bunch of parts from our host and received them on Saturday. Here is my plan: 1. Drain the gas tank and replace the fuel sender gasket (done) 2. Change the engine oil and filter (done) 3. Replace the oil drain plug and crush washer with a magnetic one (done) 4. Replace the air filter (done) 5. Replace the fuel filter (after running a bit as suggested) 6. Replace the serpentine belt (done) 7. Replace the spark plugs (done) 8. Replace the cabin filter (done) 9. Flush the coolant (Thursday) 10. Flush the brake fluid and inspect the brakes (done) 11. New battery (done) 12. Replace the rims and tires (done) 13. Inspect everything and test drive it! With the Pelican brain trust, is there anything else suggested? Thanks, David
			99 996 C4 11 Panamera 4S 83 SC Targa converted to a 964 cab (sold) 67 912 (sold) 58 Karmann Ghia choptop (traded for the 912) Last edited by DavidI; 05-25-2024 at 05:23 AM.. Reason: Updated Tasks  |
			 Behind the Sun
			Nice.
	Check for critters nesting in any possible place you can imagine. Filter housings under carpets, seats engine bay. exhaust ac vents under wheel wells  |
			 Model Citizen
			When you hook up your new battery and before you turn the key, take a tour around the car listening for sizzling and getting your nose in all the crevices sniffing for burning wires.
			(That's a nice toy to have fall in your lap! Congratulations!)
	"I would be a tone-deaf heathen if I didn't call the engine astounding. If it had been invented solely to make noise, there would be shrines to it in Rome"  |
			In case you didn't know that car has the optional " aero " upgrade package . That consists of taco rear wing and GT3 rocker covers and front bumper . Nice score . I have a 99 C4 with a 3.8 they are fun mountain carvers .
			You have a good list of maintenance to start with . I used Motul synthetic gear oil in the transaxle and front diff . Butter smooth shifting but any top quality gear oil will work . Just do a good solid baseline maintenance and drive her . Then you can plan upgrades as needed/wanted . Good luck and have fun
	2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler .  |
			Run the remaining old fuel out through the old fuel filter before you install the new one.
			There will be crap that you miss in the tank/lines.
	"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands."  |
			Great find. The rear humps on the C4 really wake that car up. Best 996 there is looks wise.
	On powering up, Tony Callas would tell you to bring it up slow with a variac. Now since those are for main house line voltage AC, they are not for 12v DC. Find something. If nothing else, use lower voltage batteries and resistors. Don't disconnect once you get voltage flowing, you can leapfrog the next step. Give the steps a few minutes each so you can watch and listen. Likely there will be no problem but you could create one by just placing 12 volts on the system suddenly. The least you can do is plug in a 9v smoke alarm battery at first in the fuse panel in the correct place. There is no significant amperage. I always leave a 9v battery connected when disconnecting the main battery. You'll need the radio code too.  |
			I honestly don't think Red looks good on you, David, but it does me...so
			![]() Beautiful find. Jelly.
	1996 FJ80.  |
			Check that the brake calipers are moving freely.
			Also be prepared to address the AOS
	Matthew - drove Nurburgring with wipers on and no rain 1969 911E SOLD ![]() 2002 996 Cabrio 1995 993 Carrera 4 SOLD 2004 Land Rover Discovery II G4 Edition (Sold  )
			If you ever need to replace the AOS consider the UAOS ........ Ultimate Air Oil Separator . Developed by a retired Porsche tech it is a once and done solution . Porsche has revised the AOS at least 8 times and it's still crap . The rubber diaphragm is too weak and fragile . The UAOS uses an OEM diaphragm moved up by the throttle body . It can be replaced in 10 minutes and is twice as thick as the Porsche unit and made of Viton.  Do a search for UAOS and there is hours of reading available  .
			 Counterclockwise?
			Nice find!
			Was it a steal of a deal?
	Rod 1986 Carrera 2001 996TT A bunch of stuff with spark plugs  |
Great suggestion!  Did a thorough inspection today and found no trace of critters.
	99 996 C4 11 Panamera 4S 83 SC Targa converted to a 964 cab (sold) 67 912 (sold) 58 Karmann Ghia choptop (traded for the 912)  |
Will do and thank you!
While working on the car today, I considered this and was going to ask later today.  Thanks for answering it for me sir!
It was pure luck and timing sir!  Thank you Paul!
Thank you Matthew!
Yes!  The owner was a multi-millionaire and wanted to get rid of it quickly.  Pure luck on my part.
			Color me green with envy and I don't even like red cars.
	Scott '78 SC mit Sportomatic - Sold  |
