DavidI's Avatar
Retirement Project - 996
Last week, I was called by a longtime friend who told me about an opportunity to purchase a 1999 996 C4 for a great price. The car had been parked in his neighbor's garage under a cover for the past 12 years. His neighbor has sold the home and wanted to quickly sell the Porsche. I contacted him, inspected the 996, and had it transported to my home. The tires were flat, but held air to roll it around. Of course the battery was completely dead as well.
The body and paint are in excellent shape. The interior has minimal wear and looks fantastic. The car comes with minimal records and I don't know if the IMS has been addressed.
I ordered a bunch of parts from our host and received them on Saturday.
Here is my plan:
1. Drain the gas tank and replace the fuel sender gasket (done)
2. Change the engine oil and filter (done)
3. Replace the oil drain plug and crush washer with a magnetic one (done)
4. Replace the air filter (done)
5. Replace the fuel filter (after running a bit as suggested)
6. Replace the serpentine belt (done)
7. Replace the spark plugs (done)
8. Replace the cabin filter (done)
9. Flush the coolant (Thursday)
10. Flush the brake fluid and inspect the brakes (done)
11. New battery (done)
12. Replace the rims and tires (done)
13. Inspect everything and test drive it!
With the Pelican brain trust, is there anything else suggested? Thanks, David
99 996 C4
11 Panamera 4S
83 SC Targa converted to a 964 cab (sold)
67 912 (sold)
58 Karmann Ghia choptop (traded for the 912)
Old 05-07-2024, 07:13 AM
Behind the Sun
Nice.
Check for critters nesting in any possible place you can imagine.
Filter housings
under carpets, seats
engine bay.
exhaust
ac vents
under wheel wells
Old 05-07-2024, 07:16 AM
Model Citizen
herr_oberst's Avatar
When you hook up your new battery and before you turn the key, take a tour around the car listening for sizzling and getting your nose in all the crevices sniffing for burning wires.
(That's a nice toy to have fall in your lap! Congratulations!)
Old 05-07-2024, 07:23 AM
rfuerst911sc's Avatar
In case you didn't know that car has the optional " aero " upgrade package . That consists of taco rear wing and GT3 rocker covers and front bumper . Nice score . I have a 99 C4 with a 3.8 they are fun mountain carvers .
You have a good list of maintenance to start with . I used Motul synthetic gear oil in the transaxle and front diff . Butter smooth shifting but any top quality gear oil will work . Just do a good solid baseline maintenance and drive her . Then you can plan upgrades as needed/wanted . Good luck and have fun
Old 05-07-2024, 08:37 AM
Run the remaining old fuel out through the old fuel filter before you install the new one.
There will be crap that you miss in the tank/lines.
Old 05-07-2024, 08:44 AM
Zeke's Avatar
Great find. The rear humps on the C4 really wake that car up. Best 996 there is looks wise.
On powering up, Tony Callas would tell you to bring it up slow with a variac. Now since those are for main house line voltage AC, they are not for 12v DC. Find something. If nothing else, use lower voltage batteries and resistors. Don't disconnect once you get voltage flowing, you can leapfrog the next step. Give the steps a few minutes each so you can watch and listen. Likely there will be no problem but you could create one by just placing 12 volts on the system suddenly. The least you can do is plug in a 9v smoke alarm battery at first in the fuse panel in the correct place. There is no significant amperage. I always leave a 9v battery connected when disconnecting the main battery. You'll need the radio code too.
Seahawk's Avatar
I honestly don't think Red looks good on you, David, but it does me...so
Beautiful find. Jelly.
1996 FJ80.
Old 05-07-2024, 09:37 AM
Check that the brake calipers are moving freely.
Also be prepared to address the AOS
1969 911E SOLD
2002 996 Cabrio
1995 993 Carrera 4 SOLD
Old 05-07-2024, 11:33 AM
If you ever need to replace the AOS consider the UAOS ........ Ultimate Air Oil Separator . Developed by a retired Porsche tech it is a once and done solution . Porsche has revised the AOS at least 8 times and it's still crap . The rubber diaphragm is too weak and fragile . The UAOS uses an OEM diaphragm moved up by the throttle body . It can be replaced in 10 minutes and is twice as thick as the Porsche unit and made of Viton. Do a search for UAOS and there is hours of reading available .
Old 05-07-2024, 11:46 AM
Counterclockwise?
Nice find!
Was it a steal of a deal?
Rod
1986 Carrera
2001 996TT
Old 05-07-2024, 11:53 AM
DavidI's Avatar
Originally Posted by 2.7RS View Post
Nice.
Filter housings
engine bay.
exhaust
ac vents
under wheel wells
Great suggestion! Did a thorough inspection today and found no trace of critters.
99 996 C4
11 Panamera 4S
67 912 (sold)
Old 05-07-2024, 03:04 PM
DavidI's Avatar
Will do and thank you!
99 996 C4
11 Panamera 4S
67 912 (sold)
Old 05-07-2024, 03:05 PM
DavidI's Avatar
Thank you sir! The Cup Aerokit gives it a cool look. Thanks for the transaxle oil suggestion.
99 996 C4
11 Panamera 4S
67 912 (sold)
Old 05-07-2024, 03:06 PM
DavidI's Avatar
While working on the car today, I considered this and was going to ask later today. Thanks for answering it for me sir!
99 996 C4
11 Panamera 4S
67 912 (sold)
Old 05-07-2024, 03:07 PM
DavidI's Avatar
Thanks Milt! I had not considered this. Much appreciated sir!
99 996 C4
11 Panamera 4S
67 912 (sold)
Old 05-07-2024, 03:09 PM
DavidI's Avatar
It was pure luck and timing sir! Thank you Paul!
99 996 C4
11 Panamera 4S
67 912 (sold)
Old 05-07-2024, 03:10 PM
DavidI's Avatar
Thank you Matthew!
99 996 C4
11 Panamera 4S
67 912 (sold)
DavidI's Avatar
Thank you. I have not heard about this. Much appreciated!
99 996 C4
11 Panamera 4S
67 912 (sold)
Old 05-07-2024, 03:12 PM
DavidI's Avatar
Originally Posted by 911 Rod View Post
Nice find!
Yes! The owner was a multi-millionaire and wanted to get rid of it quickly. Pure luck on my part.
99 996 C4
11 Panamera 4S
67 912 (sold)
Old 05-07-2024, 03:13 PM
Color me green with envy and I don't even like red cars.
Scott
'78 SC mit Sportomatic - Sold
Old 05-07-2024, 03:18 PM
