Seeking Advice - Drilling into Marble Tile
I need to drill into the marble tile bathroom I just finished. Primarily for towel racks, toilet paper holder, and pedestal sink.
I'm not sure what type of drill bits I should use. I will definitely practice on a scrap piece of tile first, but I thought I would enquire here as we seem to have a lot of experts on the forum. One worry I have is that I think I should be cooling the bit with water but I will be drilling on a vertical wall. I'm open to suggestions - Thanks! |
Tile that needs to be drilled:
masonry bit, I believe would be the way to go. Fortunately, marble is one of the softer natural stones.
I have done quite a lot of marble, the safest bet is a diamond bit, about $15, the end is blunt and just wears a hole through the marble. A carbide burr would also get through. Keep a vacuum on it to get rid of the dust.
87 930, |
I'd recommend a diamond bit as well. I've used one to drill two holes into a large bathroom mirror to install one of those flexible arm - expanding makeup mirrors near my wife's sink. Easy peasey.
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
How bit are the holes. If its for plugs, use these diamond bits. I assume the hole is 3/16". check the size accordingly
I will add, don’t use the hammer setting if you’re using a hammer drill, just straight drill mode.
Rutager West 1977 911S Targa Chocolate Brown |
Model Citizen
A diamond bit and a mai-tai from the tiki bar.
Drill the holes, clean up the mess, put the tools away and survey your work and bask in the manliness of a job well done with a Polynesian cocktail.
"I would be a tone-deaf heathen if I didn't call the engine astounding. If it had been invented solely to make noise, there would be shrines to it in Rome" |
Model Citizen
This is a seriously measure twice drill once project (after a sign-off from the boss
Edministrator
Drink twice. Drill once.
Good post? Leave a tip! O - $1 O - $2 O - $3 |
I would drill into the grout joint where you can. Makes it so much easier.
You need no hammer, and a bit which will either cut or abbrade the stone. I'd go with a diamond bit and slowly abrade the hole, with water cooling. A drill with a clutch will be necessary for a larger hole. Be sure you have a replacement tile available before you start. If the material won't play ball you may need to cut the tile in two through the spot, and gnaw the hole away with jaws. Sent from my SM-S918B using Tapatalk |
Diamond hole bits are cheap. $30 for a set on Amazon.
I used them for granite, so they’ll work on marble. Blue tape to prevent skidding, water to cool and starting at an angle are all your friends. |
Almost Banned Once
- Peter |
I picked up the diamond bit this weekend, but I was too lazy to get the project done. Well, not that lazy as I worked on many projects. Anyway, the hole size is 1/4" for the sink and 3/8" for the toilet paper holder. I will practice on a scrap piece of marble before the real thing.
Thanks for all the advice - I needed it. Last time I cut it twice and it was still too short. |
