-   -   Strange electrical problem, license plate light (http://forums.pelicanparts.com/off-topic-discussions/1164548-strange-electrical-problem-license-plate-light.html)
Shaun @ Tru6 07-19-2024 07:54 AM
Right side license plate light is out on my 07 328.
New bulb, no love.
Swapped left good light fixture and bulb from other side, Nope
12.4 V on the left good side across Plug terminals
11.4 V on the right bad side across Plug terminals
Got two new BMW fixtures
Left side good of course
Right side no
Measured fixture terminals
No bulb = 11.4 V
With Bulb = 0 V
is the plug bad? or something else
http://forums.pelicanparts.com/uploa...1721400734.jpg
Old originals, lines show check voltage
Rusty Heap 07-19-2024 08:50 AM
Bad ground. Sounds like you have a "floating" 12 vdc you can measure, but when put under load it goes to 0 v?
1990C4S 07-19-2024 08:54 AM
Where are you measuring voltage? On the connector? Or connector pin to a local ground?
Also, measure the bulb resistance in your hand, them compare that to the resistance read on the connector (bulb side) pins.
Shaun @ Tru6 07-19-2024 08:58 AM
I think that's correct.
Shaun @ Tru6 07-19-2024 09:00 AM
Originally Posted by 1990C4S (Post 12287193)
Where are you measuring? On the connector? Or connector pin to a local ground?
When I put the Fluke probes into connector holes, I measure 11.4
When I plug in the fixture, no bulb and measure across the contacts (pic with red lines), I get 11.4
When I put the bulb in, goes to 0
1990C4S 07-19-2024 09:13 AM
Check the resistance on the other side of the connector with the bulb in. I wonder if you have a short and the output is being turned off.
908/930 07-19-2024 09:50 AM
After the relay I think there is a connector for the two positive lines feeding the lights, the left side goes through and the right taps into it. Likely a bad connection there. Follow the wires back and see if you find anything.
blucille 07-19-2024 09:59 AM
isn't the left side just 8" away, why not string two new wires from the light that works to the one that doesn't?
Shaun @ Tru6 07-19-2024 10:08 AM
All good advice, going out again after work.
the wiring is mostly hidden in the truck lid. I will make a short ground connector from the left to the right.
fastfredracing 07-19-2024 10:38 AM
You need a good concrete chisel .
masraum 07-19-2024 10:46 AM
LOL! You caught me off guard with this one. Thank goodness I wasn't drinking anything.
908/930 07-19-2024 11:10 AM
I can lend you my Hilti TE-80ATC, that should open up body panels pretty quick so you can find the wire.
Shaun @ Tru6 07-19-2024 03:49 PM
OK, here's the scoop.
35 ohms across the bad side bulb
Attempted to bridge the ground wire connectors left to right but but my chisel collection was either 7" or closer to 9 so they wouldn't work, classic Goldilocks syndrome, needed 8" (that's what she said). So I made a temporary wire connection across the ground wire terminals, IIRC, grey is ground in German cars. Anyway, that worked perfectly. No need to bridge the brown wires.
I don't like those little clamp on splicers. What would be a good quality or factory way to make that connection permanent?
pwd72s 07-19-2024 11:11 PM
To answer your last question...19 minutes, well worth it.
https://www.youtube.com/watch?v=E_m8xf3vfYE&ab_channel=IrvinOrtega
Another option:
https://www.youtube.com/watch?v=dImF86OwiK8&ab_channel=electronicsNmore
Superman 07-19-2024 11:34 PM
Dark magic, obviously. Have you pissed off any sorcerers lately?
1990C4S 07-20-2024 04:50 AM
That's like asking 'what oil should I use, and do I need ZDDP?'.
I always solder, tape, and then shrink wrap. Lots of people say that's a hack and it will fail. It has never failed me. I like to do a good wrap with the two wires, I think there is actually a NASA approved warp if you search.
Butt splices with a proper crimp tool are also good. I like the shrink wrap to hide the mess and keep water out.
I have a soldered and shrink wrapped connection submerged in my pool 24/7 on my robot, it is fine.
Shaun @ Tru6 07-20-2024 05:02 AM
Thanks, I have generally soldered and shrinkwrapped too. Ducati headlight last summer. Lot of vibration, still working fine. I like the connections Paul posted too.
http://forums.pelicanparts.com/uploa...1721476866.jpg
Tobra 07-20-2024 05:14 AM
That sort of looks like the front of my wife's truck after someone stole the front off it
I always thought solder/shrink wrap was more permanent. Works better than the crimpy way, whether you have the right tool or not, seems to be pretty durable too
