Strange electrical problem, license plate light
Right side license plate light is out on my 07 328.
New bulb, no love. Swapped left good light fixture and bulb from other side, Nope 12.4 V on the left good side across Plug terminals 11.4 V on the right bad side across Plug terminals Got two new BMW fixtures Left side good of course Right side no Measured fixture terminals No bulb = 11.4 V With Bulb = 0 V is the plug bad? or something else ![]() Old originals, lines show check voltage
Tru6 Restoration & Design |
Evil Genius
Bad ground. Sounds like you have a "floating" 12 vdc you can measure, but when put under load it goes to 0 v?
Life is a big ocean to swim in. Wag more, bark less.
Where are you measuring voltage? On the connector? Or connector pin to a local ground?
Also, measure the bulb resistance in your hand, them compare that to the resistance read on the connector (bulb side) pins.
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." Last edited by 1990C4S; 07-19-2024 at 09:03 AM.. |
I think that's correct.
When I plug in the fixture, no bulb and measure across the contacts (pic with red lines), I get 11.4 When I put the bulb in, goes to 0
Check the resistance on the other side of the connector with the bulb in. I wonder if you have a short and the output is being turned off.
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." |
After the relay I think there is a connector for the two positive lines feeding the lights, the left side goes through and the right taps into it. Likely a bad connection there. Follow the wires back and see if you find anything.
87 930, |
Been here a while
isn't the left side just 8" away, why not string two new wires from the light that works to the one that doesn't?
looking for 1972 911t motor XR584, S/N 6121622 |
All good advice, going out again after work.
the wiring is mostly hidden in the truck lid. I will make a short ground connector from the left to the right.
You need a good concrete chisel .
No left turn un stoned |
LOL! You caught me off guard with this one. Thank goodness I wasn't drinking anything.
I can lend you my Hilti TE-80ATC, that should open up body panels pretty quick so you can find the wire.
87 930, |
OK, here's the scoop.
35 ohms across the bad side bulb Attempted to bridge the ground wire connectors left to right but but my chisel collection was either 7" or closer to 9 so they wouldn't work, classic Goldilocks syndrome, needed 8" (that's what she said). So I made a temporary wire connection across the ground wire terminals, IIRC, grey is ground in German cars. Anyway, that worked perfectly. No need to bridge the brown wires. I don't like those little clamp on splicers. What would be a good quality or factory way to make that connection permanent?
To answer your last question...19 minutes, well worth it.
https://www.youtube.com/watch?v=E_m8xf3vfYE&ab_channel=IrvinOrtega Another option: https://www.youtube.com/watch?v=dImF86OwiK8&ab_channel=electronicsNmore
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) Last edited by pwd72s; 07-19-2024 at 11:21 PM.. |
Senior Member
Dark magic, obviously. Have you pissed off any sorcerers lately?
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
I always solder, tape, and then shrink wrap. Lots of people say that's a hack and it will fail. It has never failed me. I like to do a good wrap with the two wires, I think there is actually a NASA approved warp if you search. Butt splices with a proper crimp tool are also good. I like the shrink wrap to hide the mess and keep water out. I have a soldered and shrink wrapped connection submerged in my pool 24/7 on my robot, it is fine.
Thanks, I have generally soldered and shrinkwrapped too. Ducati headlight last summer. Lot of vibration, still working fine. I like the connections Paul posted too.
Control Group
That sort of looks like the front of my wife's truck after someone stole the front off it
I always thought solder/shrink wrap was more permanent. Works better than the crimpy way, whether you have the right tool or not, seems to be pretty durable too
She was the kindest person I ever met |
