-   -   Best tool for job (http://forums.pelicanparts.com/off-topic-discussions/1165659-best-tool-job.html)
DWBOX2000 08-15-2024 04:49 AM
Best tool for job
I want to remove welds from boxster muffler. In tight spot. Trying to remove tips. My grinder wheel is too big without grinding other parts of muffler.
unclebilly 08-15-2024 05:08 AM
Can you remove the muffler to improve access?
masraum 08-15-2024 05:10 AM
That's what popped into my head as well. Isn't the muffler assembly just bolted on? Once it's out then there should be more room for more tools.
DWBOX2000 08-15-2024 05:18 AM
Sorry, muffler off car on bench.
Shaun @ Tru6 08-15-2024 05:25 AM
Astro Pneumatic Tool 218 1/8" Pencil Type Die Grinder - 56,000RPM,Black,gold,blue, 42377
http://forums.pelicanparts.com/uploa...1723724770.jpg
Shaun @ Tru6 08-15-2024 05:31 AM
http://forums.pelicanparts.com/uploa...1723725042.jpg
DWBOX2000 08-15-2024 05:31 AM
Looking at tools, probably better off just having muffler shop grind off. It’s a one time job.
Bob Kontak 08-15-2024 05:44 AM
Why wouldn't you post a picture of your muffler?
Shaun's kit is awesome. I'm not so sure a muffler shop is going to have better than that for close quarters.
DWBOX2000 08-15-2024 05:59 AM
I tried, my phone didn’t cooperate.
It’s not that a shop won’t have a better tool, it’s that it is probably a 1/4 the price for something I’ll likely never use again.
DWBOX2000 08-15-2024 06:01 AM
http://forums.pelicanparts.com/uploa...1723726811.jpg
1990C4S 08-15-2024 06:06 AM
Carbide burr on an die grinder, liker Shaun posted.
Do you want to salvage the tip? Or is it going to be scrapped? What's the end goal?
If the tip is scrap, go at with a zip cut on a grinder.
DWBOX2000 08-15-2024 06:07 AM
What the heck, I just bought Shaun’s tool. If it don’t work, I’ll use it to shape rocks.
Thanks all.
Shaun @ Tru6 08-15-2024 07:26 AM
Dremel Max Life 9903HP 1/8" (3.2mm) Tungsten Carbide Rotary Tool Carving Bit
DWBOX2000 08-15-2024 07:36 AM
I’ll check them out Shaun. Thanks
Bob Kontak 08-15-2024 07:42 AM
I'll buy from you what you paid for it and split shipping. I'll even pay shipping. Get the Dremel cut off wheels as well with the arbor/mandrell.
I have a hefty Dremel but not the pencil grinder.
I'll bet you keep them. :-)
https://www.homedepot.com/b/Tools-Power-Tool-Accessories-Rotary-Tool-Accessories/Dremel/Cutting/N-5yc1vZc25mZgrZ1z0sqfy
Shaun @ Tru6 08-15-2024 07:48 AM
Critical piece of info on the pneumatic pen. Any tool with a wide head: cut-off wheel, flap sander, wire brush (Harbor Freight has an awesome package of brushes), you have to cut the shaft down so only 1/4" max shaft is showing after inserted in the pen. At 56K RPM, the heads which aren't perfectly balanced makes the shaft bend over like wind on a blade of grass.
For straight shafts like burrs and diamond bits, you don't need to cut them down.
It is an extremely useful tool. I use mine for so much from polishing the insides of Allen bolts for plating to cutting and grinding and shaping everything else.
fastfredracing 08-15-2024 10:45 AM
Darn you guys and your fancy tools. I must have one of those now
Baz 08-15-2024 10:54 AM
As far as getting into tight spots, I bought this flex shaft attachment for my Dremel about 5 years ago and it's paid for itself a million times over.
Great for metal rehab and cleaning up carb and brake components!
Dremel Flex Shaft Rotary Tool Attachment with Comfort Grip and 36” Long Cable
<iframe width="718" height="404" src="https://www.youtube.com/embed/IOMai21_9bk" title="Master the Dremel Flex Shaft: Essential Guide to Upgrade, Use, and Attach, DIY Tool Tips &amp; Tutorials" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" referrerpolicy="strict-origin-when-cross-origin" allowfullscreen></iframe>
Eric Hahl 08-15-2024 10:57 AM
Multi tool?
https://images.thdstatic.com/product...-20-c3_600.jpg
HobieMarty 08-15-2024 11:06 AM
That's pretty cool. I was thinking a cordless Dremel with a cut off wheel.
