Senior Member
Yes, you are.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Air Medal or two
For those who are of serious intellect here and students (always learning) please pay atn.
There are a bunch of engines that are being produced today that were also being produced before the advent of the 0W20 oils. Toyota is just one of them. There is a UTUBE Vid on this . The producer showed it all , dwn to the size of the bolts.! The interesting part is that these engines required 5W30 prior to the 0 W 20 fad. Now 0W20 is recommended, go figure. And no, no production line changes on the line cards. None Right down to the last nut, bolt and bearing. Now with the B58 (BMW) there have been some mods. They have removed the plastic liner thing in the oil pump and replaced with steel of sorts. (the plastic cracked) As I said, this deal with 0W20 is strictly a fuel milage incentive mandated by big government. You all do as you wish.
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between |
Banned
of course the bolts are the same. they are all standard parts. specifications change all the time on a production line. tolerances, couple thousandths of an inch here, couple there. heat treating. casting quality. new suppliers, who also have there own processes that change all the time. things change due to tool wear, tooling quality etc etc. just because an engine was made 20 years ago, doesnt mean it hasnt changed. it has changed a million ways. have you ever actually looked at an engine? i have 4 mazda b6s that were all made within 5 years, and all of them are different. but the bolts will be same ![]() ![]() ![]() ![]() |
Air Medal or two
If you could read......
Banned
Air Medal or two
As I said, a serious student (who could read / comprehend) will find the swap to 0W20 is at least diametrical and quantitative to the jabbing arguments here.
The 0W20 requirement is certainly a totalitarian mandated requirement and a politically gobermendated motivated program..
Banned
your bizarre paranoid rantings about the goberment have no place here. |
MAGA
I run what the book says in most of my newer cars. On older high mileage cars, I have often bumped up a "tad" on viscosity numbers assuming some wear or if I was only driving the car in the summer months. All that said, I have never had an engine failure due to lubrication and I typically drive all of my cars well past 200K even past 300k on a BMW 325. I typically just buy Walmart or O'reillys branded
cheap synthetic oil for my modern cars and same branded dyno oil for my older stuff. Oil gets changed around when the owners manual says to change it... Never sooner but sometimes a bit later. ![]() ![]() Here is my take on it.... New cars are built with much tighter tolerances in regard to pressurized plain bearings. They get away with this because they are manufactured with tighter tolerances and the engine temps are better regulated which means the bearing gaps stay more uniform during operation. This is why the thin oil works in todays motors. Too thick of oil will mean some of these bearings may not get pressurized enough to provide the proper oil film. Older cars like from the 70's and 80's had larger bearing clearances and thus required the heavier weight oil. Not so much anymore.
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne 0% Liberal Men do not quit playing because they get old.... They get old because they quit playing. |
Air Medal or two
As stated- the SAME engines B4 0 W 20 and after, have the same bearing clearances.
These same engines in other countries do not require the 0W 20 oils. SO It is pretty clear to me, this is mandated crap. Of course, everyone is allowed to reach whatever their conclusion is; however, with all the evidence here, it is pretty clear what the answer is.
Still here
Air Medal or two
High mileage oil has seal sweller in it to help control leaks.
Ive consulted experts on specialty oils for use in highly specific harsh use equipment, had a tour of a boutique oil mfg, my next door neighbor is a PHD lubrication specialist at Exxon mobile.
I have no expertise on the matter, but the one thing I have learned for certain is to not trust amateur internet opinions or even high level data potentially taken out of context. There is a lot of potential for unintended consequences here, so I'm going with with what is precisely recommended.
84 930 07 Exige S |
Still here
Steve '08 Boxster RS60 Spyder #0099/1960 - never named a car before, but this is Charlotte. '88 targa ![]() |
I agree with the whole article, Burnie, especially the words "arbitrarily choose." Following the manufacturer's recommendation is not an arbitrary choice.
Air Medal or two
masraum
- Thank you! I hate being right all the time.....LOL
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between Last edited by afterburn 549; 05-03-2025 at 11:50 AM.. |
Brew Master
I'm gonna have to start watching this masraum character... reviving a seven month old thread... pretty suspicious...
![]() Good video btw.
Nick |
Air Medal or two
But history combined with current facts makes for the newest info.
The scoffers now are getting educated. We all need watching......LOL
Brew Master
Brother, ain't that the truth!
Nick |
All your base are belong to us!
Thread Tools | |
Rate This Thread | |
