LinkBack | Thread Tools | Rate Thread |
Counterclockwise?
I would try taking it apart and then just put it back together. Longer screws etc.
Rod 1986 Carrera 2001 996TT A bunch of stuff with spark plugs |
Nothing wrong with that thing. Needs a new back to stiff the structure up. There should be a back on there, remove it and install a 1/2" CDX plywood back. Measure both corners or diagonals and get it sq up, nail it and it will last a long time. As far as the face frame goes, just nail on new pieces if not, re-nail existing but use glue. Dig the hole about 16" down insert the pole, pour concrete. Make sure concrete is a bit above grade with slope if that's even important. Use a couple of stakes to keep the structure plum.
I don’t have any advice to offer. I just want to see the final product.
BTW, there are really no cuts needed on the table if you can go get that 1/2" back cut at home depot.
Here are a few old pics of student's projects when I taught school. The two bench were made by a couple of 15 and 17 year old girls. The floating coffee table was made by 16 year old boy. Oh yeah, they know how to sue the table saw safely. Last edited by look 171; 10-11-2024 at 04:20 PM.. |
Sorry, forgot the pics
Brew Master
Nick |
weekend wOrrier
2 cent advice-
If you decide to remake it, try to avoid plywood. I made my wife a mailbox and used similar plywood. Problem is, moisture soaks between the plys and rips them apart. I got the "opportunity" to start over from scratch about 2 years later. ![]() This is an environment where single solid pieces rule out over ply. Good luck! R
100% narcissist |
weekend wOrrier
Baz, I bet if you asked nicely, and provided a detailed plan of every piece needed, bird parts members would each cut you a piece and send them to you.
A birds parts bird feeder for books. You'd assemble and be done with it. This would, of course, require a very good plan. People would sign up for each individual piece and send it in.
100% narcissist |
On Tour
Dang those hoodlums, I love those little libraries. Have a couple by my house I use all the time. Good on you for getting it back in proper shape.
- 2018 Cayenne S 958.2 - 1988 Carrera 3.2 Coupe Marine Blue (SOLD) |
Platinum Member
New door. Coat of paint. Call it a day.
Or let the lumberyard or depot make the rips for you. You can do this without a table saw. Frankly I often use a circular saw with a clamped guide.. or snapping a line and following it is ok for this type of work. As my dad used to say, ‘you’re not building a church’
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
Information Overloader
I’ve abandoned a few woodworking projects simply out of frustration. Seems like no matter how many times I cut a board it’s still too short.
Vash,
I hear you. I am not a craftsman but I seem to spend a fair amount of my time making stuff. There are wins, and, well, there are other end results. But I wanted to comment RE: the PTSD and a tablesaw. My HS Shop Teacher was pretty gifted. He was missing two and one half fingertips. At a very clean, surgical angle. Yep. Tablesaw accident. This got my attention. If he could cut off fingers, I could absolutely do the same. A lesson I have held close for 40 years. Me? First, I am left handed. Second, I am not particularly coordinated. Third, I am right eye dominant. This means shooting a simple basketball shot is pretty goofy and hilarious. It also means I am terrified of cutting something off of me - which - is a high probability. I make a point to slow down. Plan my actions. Think about stuff. Then cut. I made a pretty fair fence this summer with no accidents. I am making a 10x12 shed right now. There have been mistakes but it is coming together. I expect to put on roof decking today and tomorrow. Lots of hand sawing! Yay! But my point? Slow down. Anticipate. Use safety devices (push stick) and things are far far safer. Just don't ask about my super near miss with a router. Because that would have had me in the hospital or morgue. |
As suggested, that box doesn't look too bad, so I would save myself some grief and just refurbish what is there. Take it apart, rebuild it, add a door back to it, seal it all up well to protect the books from weather, and utilize the existing post. Easy peasy.
If you do end up sawing something, measure twice, cut once!!! Sent from my SM-S916U using Tapatalk
"A little nonsense now and then is relished by the wisest men." Wonka |
Brew Master
It's all about scale man. That board isn't cut too short, Yer just scaling the project down a bit. Trick is to cut the next board to the same size as the one that was previously thought to be too short!
Nick |
I have this idea, that Vash is eventually going to post a pic of his finished result, and it's going to be an aesthetic masterpiece that's also sturdy enough to support a tank.
Get an air (or battery) pin nailer. That will make your repairs easier.
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." |
![]() A few small finish nails and some glue will do the trick. Its needs to be repaired with a few deck screws and be done with it. Vash, is the post loose and no longer stable for the kids to knock it over? If its stable, jsut repair it. Screw down the top and fix the face frame and call it the day. When done, I want to see your face in the local papers and how you saved the day for both the young and old. Vash for city mayor |
Edministrator
Good post? Leave a tip! O - $1 O - $2 O - $3 |
Edministrator
Jesus started out as a carpenter.
