Best hinge for a door that's "invisible"
What sort of hinge is available for a door that opens into a room that is ~2.5" thick, and 18"x44" that won't (or minimally) show (wall and door will look like drywall)? I know there are cabinet door hinges that are designed for inset doors on frameless cabinets, but I am thinking that those wouldn't work for a door that's 2.5" thick. Correct me if I'm wrong. If I have to, I'll go with a regular thinner hinge in white. But it seems like there's probably something out there that I just don't know about.
There are special hinges for doing secret room doors that might work.
Look up SOSS hinges as well. |
You want a pivot hinge. The cabinet hinge likely won't manage the load of an 12" x44" door with sheetrock on it. The pivot hinge mounts to the floor and lintel of the frame and can carry pretty large loads.
https://www.swingingcafedoors.com/stainless-steel-hidden-door-pivot-hinges/?sku=SSHDPIVOT-S-O-1&gad_source=1&gclid=EAIaIQobChMI6uv_76SRiQMVhtTCB B3m3RLZEAQYAyABEgLRqPD_BwE |
2.5" door is going to be heavy.
Might look at piano hinges (runs the entire length) |
See the picture below. They're fantastic.
Are the hinges for your knee wall doors?
Cabinet hinges will not work on a thick door. You can get them for 1" door and that's usually the max. I am not sure if they make then for thicker doors? Any thing thicker, use the Soss hinges or a piano hinge and you really want to yank your hair out, do the pivot hinges.
Some of the cabinet hinges that I found looked like they were the same type/style as the SOSS, just probably cheap knock-offs. |
https://www.amazon.com/TamBee-Hidden-Invisible-Concealed-Adjustable/dp/B07WT3C7TJ/ |
the ability to adjust is huge Those should work great.
| All times are GMT -8. The time now is 07:36 PM. |
