Squirrels In The Attic
Yeah, not an Aerosmith album!!!
I've been dealing with some squirrels that decided to break into my attic. I'm going to try this one-way cage extruder thing. You attach it at the access hole, squirrels can leave for food, and they can't get back in. Does anyone have any tips about how to remove squirrels from an attic? I've also got some repellant. ![]() ![]() Sent from my SM-S916U using Tapatalk
"A little nonsense now and then is relished by the wisest men." Wonka |
Coyote urine on cotton balls. Worked for us. We plug holes with steel wool and then shoot foam sealer into the steel wool. Mothballs didn't seem to work.
http://www.autoforeignservices.com/ 57 Speedster, (4) 67S coupe's, (2) 67S targas, 68L Rally car etc. etc. |
Run smooth, run fast
Show no mercy.
- John "We had a band powerful enough to turn goat piss into gasoline." |
Almost Banned Once
Unfortunately you'll have to go full Viking on any wild animal that has decided to take up residence in your roof.
I had an issue with rats and in the end I had to get professional help.
- Peter |
Almost Banned Once
FIO: ... You can buy Coyote urine.
(And almost any other predator urine)
- Peter |
Once they get into your attic and nest, you need to kill them, to take them a loooong way away.
They will do anything to get back in.
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." |
Yesterday morning, I went up into the attic and sprayed the repellant all around pretty heavily, in fact, the smell kind of wafted into the living space and my wife opened up some windows and lit some scented candles and it was all good. When I got home from work last night, the smell was actually gone. Today, so far, I haven't heard any activity from up there. We have woods behind our house, and surprisingly, there are not many squirrels around here at all. The two that have been in the attic are usually out in a hickory tree in our backyard. I was just outside with our Yorkie, and I saw one squirrel at the edge of the woods. I find it strange that even with the woods all around us here, I can count the number of squirrels in my general area on one hand. Thanks for the tips, guys. I truly appreciate it. Sent from my SM-S916U using Tapatalk
You do not have permissi
You also need to fix where they are coming in. When my house was first half rebuilt, the insulation was missing from the top half of the ceiling and replaced by small black chunks of whatever. The smell was awful to say the least. The was space under the eves where they were getting in. Play loud music, do the urine thing, spray lysol, and reclaim the space so they leave. There is probably a branch near the roof.
Birds regularly fly up to my cracked window, chirp and flop at the screen, and check out a possible place to bed for the winter. Had to chase them out of the garage as well. Such is nature.
Meanwhile other things are still happening. |
Yes, when I know they are out of my attic I will seal the hole with some galvanized metal and paint to match the eve.
Growing up in an 1920's brick colonial this was a constant problem since the squirrels can easily scale brick. They usually got in to the attic at a corner of house where the roof eaves/gutter meet the brick in a not so perfect fit.
Step 1. Seal the hole. Seems odd to do this first, but trying to time it so they are out of the attic when you seal is a fool's errand. Just seal your perimeter in broad daylight hours and hope you get lucky. Use metal carpenter paper or tin flashing - something their teeth can't chew. Trim any trees or branches that are giving them easy access to your roof. Wires are easy access points too. Slice a plastic funnel to enable you to place it on any wire going to your roof. Face the large end of the funnel away from the house to prevent squirrels from traversing the wire. They'll start to push the funnel toward the house, so set it far enough away to buy some time, but close enough to capture any access point they have to the wire itself. If you're fortunate enough to keep them out (as opposed to trapping them) you may have to move the funnel back several times as they will keep trying their usual access point. Step 2. If squirrels remain in your attic, set up a one way live trap in the attic and buy yourself some heavy gloves. They will fight like hell in those metal traps but they work. Conventional rat snap traps don't seem to work too well with squirrels - at least in my experience. The squirrels will bloody their faces trying to chew their way out, so the gloves are very important. Step 3. If you unfortunately have to transport a trap with a live squirrel, take it across a body of water if you can, or at least a sufficient distance. Don't unload him in the park down the street. Face the trap opening toward the base of a tree and open the gate with a long stick. We had a neighbor that would accomplish step 3 in a much more simple fashion using a large garbage can full of water. That sort of thing might not be to your taste, but it solves the problem conclusively. Good luck. EDIT: That Amazon link you posted will work, with one very critical condition. You have to be able to adequately mount the trap at the access point such that they can't get around it. If they're coming in at a spot that is in the middle of a wall where you can reliably attach all 4 of those flanges to the siding, great you're in business. But in my experience, those traps are too clumsy to mount to the exterior of the access point and won't completely seal the area. They are likely getting in at a seam or corner and that trap probably won't just fit perfectly in the area you want it to. Nevertheless, if you try and it doesn't work, you can use it as an interior trap. Otherwise you can typically rent interior traps at tool rental places.
"Rust never sleeps" Last edited by MikeSid; 10-23-2024 at 02:51 PM.. |
One of my buddies used to flip houses. Buy low, fix them up, live there for a while to finish the odds and ends, and sell it.
One house he bought had a squirrel make a huge nest in the attic of a house that no one lived for several years. That house had an upstairs game room, and a door to easily walk int the attic. The squirrel nest just close to the door. He sealed up the hole and repaired the house, but he left the huge nest in place. He sterilized it with some chemicals as he rebuilt the house. He bought three ostrich eggs and put them in it. He had a 10 year old son that had lots of friends come over to play on the three pinball games, and several video games. Invariably one of the boys would ask where that door went. He would make them all get real quiet, and open the door slowly and tell the other boys they had a huge bird that live up there. When they saw the eggs, they all were blown away, and of course told their friends about it. My buddies son had a bunch of friends come see the nest.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Platinum Member
I used the rodent spray foam. It was called pest-block.
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
I've seen that stuff at Home Depot. I figured it was just the same as "Great Stuff" only marketed as rodent foam or whatever. I haven't researched it. Maybe it is treated with some sort of repellant, but I have no idea.
When I got home tonight, I checked, and the spikey ball is still right where I left it, and my family said they hadn't heard any noises from the attic all day. Maybe the repellant that I sprayed in the attic did the trick. Time will tell. Sent from my SM-S916U using Tapatalk
It is Thursday morning, and the spikey ball is still in the access hole where I placed it.
If it remains there the rest of the week, then that tells me that the squirrels have vacated the attic. My plan for the weekend is to get back up there in the attic, do a good sweep of things, and repair the access hole and any voids I see in the screen mesh on the eaves of the house and good to go!!! Sent from my SM-S916U using Tapatalk
That rubber ball was a brilliant idea. Lets you make sure the squirrels are out before you make permanent repairs.
Rutager West 1977 911S Targa Chocolate Brown |
Is the ball hard enough to get out that they couldn't pull it out from the outside?
I just want you to know that I've had Steven Tyler (on 8-track it wuz) screaming "Swirlz ... Skwirlz ... Skwirlz " in my head lately
![]() Well done! |
