LWJ LWJ is online now
OBD2 Reader?
So here is something I understand but am confused at the same time.
OBD2 scanners. I have a cheap-o from who knows where. I does read codes. Except when it doesn't. Sometimes you need to go to a legit mechanic to get the codes read because my poor scanner doesn't pick them up.
In my very simple brain I think that a digital signal is a signal is a signal. And a reader should be able to extract it.
Can anyone explain how a cheap reader can in fact read codes but at the same time not pick up other codes?
Thanks all!
Old 10-29-2024, 06:10 PM
You do not have permissi
john70t's Avatar
Some codes are proprietary to a vehicle.
(ie there are 5 computers involved in opening a sunroof on a particular model)
OBD2 is supposed to 'universal' to basic function...from 1995(Canada) or 1996(USA) i think...but things have changed.
Old 10-29-2024, 06:30 PM
WPOZZZ's Avatar
Depends on the brand. I have brand specific readers for my Audi, BMW and Porsche and they work great. If you can find one specifically for your marque instead of a generic one, you are golden. Just remember to update software.
Old 10-29-2024, 06:46 PM
Brew Master
cabmandone's Avatar
Depends on what modules it'll read as I understand it. There are a lot of generic emissions codes that virtually all readers will read but those same readers won't read all the modules. I have a Blue Driver that I'm satisfied with. I haven't had to take any of my older vehicles in to have codes read. If you want more codes it seems like you have to step up in price to a "diagnostic" scanner. Those let you do things like cycle the ABS when bleeding brakes and see transmission codes.
Nick
Old 10-30-2024, 03:34 AM
There's a reason some scanners are $20, and some are $1,500. You get access to vehicle specific codes, data streaming, and freeze frame data. My Volvo rarely shows 'check-engine', but if I scab it with Volvo's VIDA software, I will see at least ten faults/warnings.
Watch any legit mechanic on YouTube and you will only see the high-end scanners.
Old 10-30-2024, 06:13 AM
Counterclockwise?
My $20 scanner has been reading "check engine" codes for me for years on multiple cars.
It's all I have ever needed.
Rod
1986 Carrera
2001 996TT
Old 10-30-2024, 06:37 AM
Proprietary. That is a great answer. Makes sense. Thanks!
Old 10-30-2024, 09:42 AM
Fancy diagnostic scanners can actively send a lot of signals as well.
Cycle the abs solonoids for bleeding, operate the purge valves for emissions, cycle through electronic fan speeds to check operation, etc etc....
07 Exige S
Old 10-30-2024, 10:39 AM
A good scanner will also plot your boost pressure, oxygen sensor voltages, abs signals, etc.
Old 10-30-2024, 10:48 AM
Evil Genius
Rusty Heap's Avatar
The cheap $20 scanners work for cheap $20 fixes. Heck any auto-parts store will scan for free in their parking lot..........but for ABS, and higher end problems, the $200+ scanners will clear codes the cheapo's won't.
Life is a big ocean to swim in.
Wag more, bark less.
Old 10-30-2024, 12:12 PM
Brew Master
cabmandone's Avatar
My $100 Blue Driver will clear about anything and has real time logging.
Nick
Old 10-30-2024, 02:11 PM
I think the deal is that back when OBDII was created, (in the 90s) the amount of computerized data was limited. These days there's a LOT more stuff in cars that's computerized, and manufacturers have added their own stuff. Think about the fact that there's now computerized suspension, transmissions, TPMS, multiple air bags, windows, etc... that were not computerized in the 90s. I suspect that instead of updating the OBDII standard to include all of these new things, the various manufacturers just added their own stuff. So now your scanner/diagnostic tool needs to support the proprietary codes for any manufacturers that you want to scan.
Old 10-31-2024, 06:51 AM
