Removing bolt with loctite
I want to remove the studs I put into my wheel hubs. Do I put heat on the stud or the area the stud goes into? Can I reuse the stud?
Will a heat gun work or do I need a porch? Will it ruin the studs and anything else in the process?
2002 boxster rear wheels.
Thanks for your help.
Old 11-07-2024, 09:55 AM
rfuerst911sc's Avatar
Put two lug nuts on the stud , backing them tight to each other . Heat gun/torch at the base of the stud where it goes into the flange . Heat for a minute or two and back out the stud with the two lug nuts . Repeat/rinse .
On a different note just based on your previous posts on wheel studs you seem to really be struggling with the install . Hopefully you get the end result you want .
Old 11-07-2024, 10:58 AM
So just to be specific, at I heating the stud or around the stud. Just trying to avoid another screw up.
Thanks,me too. I do like the look over the studs (or maybe that it’s a little different than stick. Overall, The studs install is pretty easy overall. Rennline has instructions which I now have. Not sure why they didn’t come with studs. I got inpatient and here I am.
Old 11-07-2024, 11:15 AM
Old 11-07-2024, 11:18 AM
I have to ask , why do you want to remove the studs ?
Old 11-07-2024, 12:26 PM
908/930's Avatar
You need to get the area where the thread with the Loctite is to about 250c, not just the stud. Check that temp to what # Loctite you used.
Old 11-07-2024, 12:29 PM
I agree, why do you want to remove them?
Old 11-07-2024, 12:31 PM
The instructions say to use loctite 272 or greater. Mine is 271. Instryctions say anything lower might melt and act as a lubricant. That and my stuff was pretty old suggests I should fix. It’s a street car so not sure heat is even an issue but hate to lose a wheel.
Old 11-07-2024, 01:00 PM
908/930's Avatar
Pretty sure the loctite on the thread is just to keep the stud from backing out when removing wheel nuts, could result in not enough thread engagement in the hub. Once properly torqued they are not loosening up on their own.
Old 11-07-2024, 01:36 PM
Platinum Member
dad911's Avatar
Loctite is not used on the lugnut or stock wheel bolts. IMHO it is just to prevent the stud from coming out of the hub when you remove the nut. Once torqued properly it shouldn't matter. I would torque them, then check occasionally.
Edit: agree with 908 above... I type slower.
Old 11-07-2024, 01:38 PM
skinnerd's Avatar
Studs are usually just pressed in.
"Are you out of your Vulcan mind?"
Doug
2022 Carrera 4S, 1989 Delta Integrale, 1973 911T CIS
Old 11-07-2024, 02:54 PM
Navin Johnson
TimT's Avatar
Ffs
https://www.loctiteproducts.com/products/central-pdp.html/loctite-threadlocker-red/SAP_0201OHL029W5/variation/209741.html
Loctite Threadlocker Red 271 is a permanent solution for locking and sealing threaded fasteners and is only removable once cured by heating up parts to 500°F (260°C).
If your wheel hub is getting to 500 deg F You have some other serious problems
A quick google search
https://next.henkel-adhesives.com/us/en/products/industrial-adhesives/central-pdp.html/loctite-272/BP000000153465.html
LOCTITE® 272 is a red, medium viscosity, high strength anaerobic-curing threadlocking adhesive with high temperature resistance. It is specially designed for the permanent locking and sealing of threaded fasteners and to withstand temperatures up to 232°C (450°F)
'69 911 GT-5
'75 914 GT-3
and others
Old 11-07-2024, 03:07 PM
If and it's a big if ............ if in the future when removing a lug nut and a stud backs out fix it then . If Loctite of ANY strength was applied to the threads AND torqued to spec I seriously doubt you will have any issues .
Old 11-07-2024, 03:24 PM
I guess I’ll leave be and check periodically. Thanks everyone, case closed. Oh, I bought the stuff the instruction mentioned for the front.
Old 11-07-2024, 04:10 PM
