If this isn't "fixed" ... my posting daze are soon to be over .... it's virtually a PITA now ;)... |
Is the invalid_redirect_url_x fixed for you guys yet?
I finally ran into the same issue as some of you guys did on both my phone and 2 computers. I just re-logged in on each device and it seems back to normal now *I hope*. |
Awesome Eric.... I just posted and saw your update.
Working great for me now... Thank you :) |
When asked if a "problem" was fixed ... ???
I dunno..... Ask me again later ... much later :D |
Good here also.
Still no worky here . I can log in at my work, via desktop, mobile devices,and my phone. At home, I still get 403 access denied code. I cannot log in there with any devices, including the same phone that I login with at work. I also was able to log in with that phone, away from home last weekend, using mobile data, so I would say , it has something to do with my IP address, or my home internet config?
I already wiped my cache, cookies, and browsing data several times. I even reset back to factory defaults . This all started right around Thanksgiving like others have stated. I am not aware of any changes that happened on my end leading up to this . Its no big deal, not complaining here, I seem to get a lot more done around the house , but I just thought Id let you know, in case it is helpful to you at all I only hope that Pelican OT can manage with my reduced number of well thought out and intellectual posts in the mean time |
Everything went smoothly Eric. Thanks.
Fred, we'll struggle along, but it just won't be the same place. Merry Christmas all. |
https://www.sitelock.com/blog/how-to-fix-403-forbidden-error/ Quote:
Fred - Heal N Toe would like to know if you found a solution to this problem and what it was. Apparently he still can't access the site.
Yep, same issue. I gave up and had to go cold turkey away from this place. The wind / fire here has cause many power outages for couple days. When power came back on, just out of habit and clicked on Off Topic and it worked. Its been working ever since. I couldn't log on with my phone at home during those times neither but it does work at a local Starbucks near by. Not sure how much of this help?
Nature of the beast too.... Good luck! |
I pretty much tried everything mentioned above, and also from online searches on how to fix 304, or 403 access forbidden code .
I have also given up , and only log in here at work . Amazing how much stuff I get done at home . |
Fingers crossed! |
| All times are GMT -8. The time now is 11:05 AM. |
