-   -   Heel N Toe Needs Some Advice (http://forums.pelicanparts.com/off-topic-discussions/1171288-heel-n-toe-needs-some-advice.html)
Seahawk 12-10-2024 10:56 AM
See below. I told him I'd help but he just laughed.
Eric has allowed this thread and will help as much as possible.
PM me for Toes personal email address and I will contact you folks that can provide assistance:
Hello Pelicans,
Heel n Toe here... I began getting this message every time I clicked on my Pelican O/T forum bookmark in Firefox a couple of weeks before Thanksgiving and haven't been able to log in since:
Server Error
403: Forbidden - Access is Denied.
You do not have permission to view this directory or page using the credentials
that you supplied.
Paul and the Pelican IT department have been doing everything they can think of to help correct the problem, but haven't been able to find a solution, so I'm turning to you.
I remember seeing a thread not long before I lost access about someone else having a similar problem. If you remember that thread or were the author, was it the same problem and/or did it contain a solution?
Paul has done enough, so he doesn't need to be 'middle man' any longer
Again, I'll get you his email address if you folks PM me.
Best and thanks.
Seahawk 12-10-2024 11:11 AM
Bump
Scott Douglas 12-10-2024 12:18 PM
If I had that problem first thing I'd do is delete the bookmark.
Then I'd run CCleaner and clear the cookies and cache.
I'd then type in the URL directly, no cut or paste stuff.
Hope this might help but it's all I've got.
KFC911 12-10-2024 12:27 PM
^^^ What Scott said .... (I defer to him), but if clearing out the browser side doesn't fix it, the server database might need to be "cleared" next.
I have noticed a few db errors a few weeks back.
The daily resets at 5:30 est are obvious, bogus activity is reduced, and mebbe Pelican is just tired of H&T making stooopid posts....
Nah .... that ain't it .... I'm here still :)
Good luck!
masraum 12-10-2024 01:27 PM
Always try multiple browsers, multiple devices (PC, phone, etc...), and different networks (not just your home network, try a friend's home, via your phone's connectivity, free wifi, etc...).
If you have success via anything (other browsers, devices, networks) then the issue is with one of the things associated that didn't work (maybe your ISP and/or home network, maybe a specific browser, maybe a specific device).
Once you've done the above, and narrowed it down "it's not chrome on my phone or my kid's PC at the coffee shop" (or whatever), then you start looking at where it does fail.
It fails for all browsers and devices at home (then look at your home network, ISP, DNS).
"It fails on my PC and Firefox, but works fine on my phone or works fine via chrome on my PC" then look at your PC and Firefox.
It could be as simple as clearing cookies, cache, and history in the browser that you usually use. It could be some plug-in in the browser. It could be a "security" software blocking your connectivity. It could be that the DNS from your ISP is causing issues. (I can provide other DNS servers to test with if necessary).
My PC has 2-3 browsers. I have my phone my wife's phone, we both have PCs. I can disable the wifi on my phone and use the phone direct through the phone's Internet (instead of my wifi network via my ISP). (that usually does the trick) You can borrow a friends PC at their house and see if you get the same results (rules out your home network, devices, browsers).
I tell PP to keep me logged in, and I only login 2-3 times a year. I assume it's usually after some sort of upgrade on my PC or maintenance at PP.
fastfredracing 12-10-2024 01:40 PM
I have the same exact problem at home .I cant log on, on my lap top ,desktop nor my phone. I have no problems logging in at work on any devices , including my phone . Hopefully this is helpful ?
stevej37 12-10-2024 01:53 PM
When I had the same problem a few weeks back....I couldn't login the normal way, but I found that if I started my login at pelicanparts.com and went through the several choices....it worked.
A cookied start would not work, even after clearing my browsing data.
Eric at Pelican Parts 12-10-2024 01:58 PM
Fastfredracing, thanks for letting us know you're having the problem too, I'll pass it on.
HnT and look171 are the only two that I've been in communication within regards to this 403 error pop up which looks like this...
http://forums.pelicanparts.com/uploa...1733867743.jpg
These are a few of the things we've tried to fix it so far:
-Checking on another device or computer (problem is some people only have one device)
-Clearing cookies on browsers
-Pressing Ctrl + F5 or Cmd+Shift+R for Mac
-Manually typing in forums.pelicanparts.com
- Clicking on these two to access forums:
New style (incomplete)
(regular forum style)
Currently out of ideas along with my colleague, so we decided to open it up to the braintrust. Everything seems operational on the forum so we aren't sure what's going on.
KFC911 12-10-2024 02:25 PM
Steve Masraum offers some excellent tips/advice for isolating "where" the issue is. It's almost always on the client side ... but ...
Not knowing what happens on the server side (database flips/swaps etc), the server could be "hosed" if a db error occured while H&T was logging in, etc., and I had a few of those ... when making a post, etc. back when the site was mostly unreachable for several days.
Good luck ... Eric, thank you guys! Still lots of "things going on", but the efforts are noticed ....
And appreciated :)
masraum 12-10-2024 07:12 PM
And appreciated :)
Good point. The users with issues might also want to try creating a new user and seeing if that works. That would point at it possibly being an issue with the site/database rather than their stuff (especially if the other troubleshooting that I posted doesn't yield any fruit).
KFC911 12-11-2024 03:18 AM
I can not log in via mobile view (only desktop) this morning. Getting some type of vbulletin err msg. I was logging in to point out this....
It sounds as if these users can access the site, but simply can't log in. After clearing out the client side (on that device), then I would focus on the server db .... it smells "fishy" these daze ;).
Unlike baseball players ... network guys get as many strikes as we want fixing "our network" problems :).
280 "active users" at 5:30 am .... yippee!
KFC911 12-11-2024 03:28 AM
From mobile logon attempt ... this is from memory....
invalid_redirect_url_x
I think that was it .... hth.
KFC911 12-11-2024 03:44 AM
Mobile logon is working now :)
Bob Kontak 12-11-2024 05:04 AM
My desktop just allowed me in. Same messages. Same as a couple weeks before Thanksgiving, also.
I get the bounced message, backup a page and go back into a thread and i'm logged in. One log in, a couple extra steps.
Here's the message.
http://forums.pelicanparts.com/uploa...1733922783.jpg
http://forums.pelicanparts.com/uploa...1733923241.jpg
KFC911 12-11-2024 09:03 PM
Logging on and posting from mobile is messed up since the "change" this morning ... just fyi.
Takes you to desktop mode... no bueno.
wdfifteen 12-12-2024 08:30 AM
http://forums.pelicanparts.com/uploa...1734020876.jpg
I get this message when I try to log in from any device and that page basically locks up. But if I go back and click on the "forums" button it shows that I am logged in. It sounds like the same experience Bob is having.
wildthing 12-12-2024 08:36 AM
Mine is less egregious. It says my last visit was 11-21 but clearly I've been visiting everyday.
I would say the nuclear option almost always works: clear everything from your browser - cookies, passwords, site settings, cached files, etc.
Scott Douglas 12-12-2024 08:58 AM
I'm getting the same 'Could not find...' message too, but clicking back and then going to the forums page gets me here.
KFC911 12-12-2024 10:41 AM
It's broken but works.
This is all from the change made yesterday morning ... that Eric aluded to earlier.
Just my guess...
masraum 12-13-2024 06:21 PM
Here's the message.
I usually have Pelican set to remember me (save cookies) and my browser to keep them, so I almost never login/logout.
In the process of trying to help HnT, I logged out, and when I logged back in I got the same error as above. It's just PP trying to take you to some sort of launch page, probably the forum root. It's easy enough to delete part of the URL and hit enter or change the URL to the OT forum to get in.
Just kill the part in the red outline or replace it with something else.
http://forums.pelicanparts.com/uploa...1734142849.jpg
