My other ride is a C-130J
Bicyclists/DIYers Bowden Cable Help Request
Hi Gang,
I’ve been upgrading my street legal LSV (Low Speed Vehicle - Glorified Golf Cart Capable of 30 MPH) I’ve been doing some dash work and have run into a roadblock. After installing a more secure locking glove box the hood release cable is now about 6 inches too short. I could simply replace the Bowden cable with one that is six inches longer but that would require the disassembly of the front end of the cart to access the latch mechanism. I would rather not do that. Does anyone know of an extension that connects to the existing Bowden crossbar stop sleeve and extends the cable six inches. I really don’t want to cut the existing cable. I was hoping there would be a clamp like device to secure the end of the cable and add 6 inches. See photos . . . ![]() I’ve added a Bluetooth radio, usb port, outside temp gauge, speedometer, and voltmeter. ![]()
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic 2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer Previously Owned Art from Stuttgart 2000 Boxster -1983 911 SC Cab -1984 944 N/A Last edited by RNajarian; 12-28-2024 at 12:40 PM.. |
https://www.jbugs.com/product/16-2087.html
https://www2.cip1.com/acc-c10-2569/ Between those two you should be able to rig it, no? Last edited by Alan A; 12-28-2024 at 01:45 PM.. |
weekend wOrrier
I looked up bike cable extenders such as:
They are expensive, but would require you to cut the existing cable end to insert. Another option is from porkchop BMX- https://www.porkchopbmx.com/porkchop-bmx-porkvert-bicycle-gyro-upper-brake-cab.html This is a 2 into one splitter, but I bet it would work just using one to one. Now, what you'd have to do is dremel a slot into one of the 3 holes on the naked aluminum piece so you could slide in your existing cable without cutting the end, but it should work, and is the cheapest thing out there. All other cable spltters seem to be in $50 dollar range. This is another splitter that would accomodate the cable end. It is a 2 into one, but would probably require you to dremel the outside of the cable extender housing to fit your cable . Also $$$ https://www.xvkdfashion.shop/?path=page/ggitem&ggpid=2426868 Personally, I'd go ahead and cut the round ball off the end of your existing cable, or just get a longer cable. Sorry I couldn't find a direct plug and play. These all require fidgetting. Perhaps someone else will have a better idea. Other random splitters ($$$ and would still require cutting cable) https://www.jtekengineering.com/products/double-control-model-l/ https://problemsolversbike.com/products/cable-doubler At this price point and rednecking level, it might make sense to get a longer proper cable. Last edited by LEAKYSEALS951; 12-28-2024 at 03:39 PM.. |
Thanks gents for the input….
Let me research these options and figure out the best solution
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic 2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer Previously Owned Art from Stuttgart 2000 Boxster -1983 911 SC Cab -1984 944 N/A |
Iv done that many times. Just use a regular cable stop might have to drill it out to fit two cables. Make a U shaped bracket and thread it to fit bicycle cable adjusters that will hold the cable. Then you can even have the factory end at the latch
82 SC , 72 914 Last edited by porsche930dude; 12-28-2024 at 07:25 PM.. |
Assuming you've got a dremel tool - use a wire rope crimp such as below. I'm assuming you've got another cable you'll attach to extend the 6 inches or so you need. Cut a slot into each side of the crimp that would allow the cable to slide through and the cylindrical end would sit inside. Then epoxy or JB weld the parts inside.
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
Also, if you’re going to use a bicycle cable, make sure you use a heavier duty mountain bike cable.
Byron ![]() 20+ year PCA member ![]() Many Cool Porsches, Projects& Parts, Vintage BMX bikes too |
THAT’S IT !
Thanks guys
I think the part I need is a parking brake connector . . .
Cool vehicle!!!
Inquiring minds need to know which option you chose please.
After all the great ideas that came from this thread I decided to go this route . . .
As stated in the opening post I didn’t want to disassemble the entire front end of the vehicle to access the latch mechanism. Ideally I would install the correct length and eliminate the need for an extension. Instead, I merely wanted a way to extend the cable six inches and place the hood release handle in the locked glove box and avoid the front end disassembly. I ordered an emergency brake cable connector to attach to the Bowden crossbar stop sleeve that attaches to the original hood release mechanism. ![]() ![]() ![]() ![]() To extend the six inches needed to get into the new glove box I ordered a hood release handle and cable to put in the glove box extending to the emergency brake cable connector. ![]() I should be able to cut to the right length and attach the extension to the brake cable connector. Once all the goodies get delivered and installed I’ll update the group. Thanks again everyone for your help
