Control Group
It is crazy expensive in California. Lows in the 40's, highs in the 60's $300 a month for heat
She was the kindest person I ever met |
Brew Master
Geothermal is gonna cost some serious coin. I'd go 2 stage heat pump with 2 stage gas furnace. I recently installed a variable speed heat pump and modulating gas furnace in my house. Since I buy at dealer cost that takes the OUCH out a bit. But my system was still pricey.
How old are ya and how long do you plan to live there? I'm beyond impressed with what my system is capable of doing. The problem is, for the average consumer the equipment alone will run North of 15K. I installed mine in two days so 2K for labor would be about right. Is your current furnace an 80% with metal vent or 90%+ with pvc vent? Oh and yesterday, according to my thermostat, it cost me $5.11 to heat my home at 70 degrees while the outdoor temp was around 19.
Nick Last edited by cabmandone; 01-10-2025 at 01:00 PM.. |
Southern Class & Sass
I pay about $100 a year, if that, to heat my home.
I pay about $1,100 a year to cool my home. My home is 950sq/ft
Dixie Bradenton, FL 2013 Camaro ZL1 |
We've spoken to a guy about replacing our unit. He's the same guy that's repaired and recharged our unit a couple of times. He's pushing hard for Mitsubishi mini-splits. I think that would mean 6-8 units which sounds expensive. We'd like to just replace the central unit that we've got with a much better heat pump. I'll probably eventually just have to find other companies to call which can be more of a pain in the country than in town.
Steve '08 Boxster RS60 Spyder #0099/1960 - never named a car before, but this is Charlotte. '88 targa ![]() Last edited by masraum; 01-10-2025 at 01:13 PM.. |
Not sure what my heating cost is per year....but I found out my electric bill had doubled a few days ago.
It was hanging near $170/month. Dec bill was $350
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI |
Around $400 month using oil boiler with radiators and heated floor, or heat pumps with electric back up. It costs about the same, but the boiler is more comfortable. House is about 3400 sq ft.
Peppy 2011 BMW 335d 1988 Targa 3.4 ![]() 2001 Jetta TDI dead 1982 Chevette Diesel SOLD ![]() |
Is that just the increase due to "nice fall temps" to "sucky winter temps" or did something change, like the power company doubled the cost or you started leaving the windows open all night?
Steve '08 Boxster RS60 Spyder #0099/1960 - never named a car before, but this is Charlotte. '88 targa ![]() |
2009 Cayman PDK With a few tweaks |
Brew Master
Nick |
Brew Master
BTW Fred, if ya wanna talk HVAC shoot me a PM and I'll send you my number.
Nick |
Part is the colder weather...I'm going to check if there was a rate increase. Other than that, I don't know. Never had an increase of 100% before.
Information Overloader
Hundred bucks a month if I leave a window open just a crack all year long.
My house is 55° at 4 AM in the dead of winter. At 7AM or so, it’s near 70°, when I get up. All day long it’s 65° until 10PM, when I go to bed. Then it slowly drops back down to 55. My gas consumption is 25% per month less than the lowest cohort of efficient house of my size in my location. Plus, I sleep pretty good. |
Masraum: FYI the outside mini split unit can be purchased with a multi head manifold . Meaning one outside unit can run 4-5 inside units . Many mini splits are now 24 SEER or higher which significantly lowers heating and cooling costs .
Our 18 SEER dual fuel heat pump and propane furnace is what I consider the next best option . Obviously this is a more conventional install and uses existing ductwork . We replaced an existing 10 SEER and we easily save 30 % to 40 % monthly with the newer unit . Many installers are still stuck in the past regarding mini splits . Find a good installer and get an accurate assessment and quote . Likewise do the same for a more conventional heat pump . Be prepared for sticker shock as prices have jumped up due to new refrigerant requirements . |
This kind of thing. ![]()
I set mine at 72 for winter and 75 for summer....year around. I can stand heat easily....cold, not so much. .
Parrothead member
My house is 3900 sq ft. Gas forced hot air. Usually keep it around 72 during the day, 68 at night. On the average it is about $225-300, dependent on outside temp. Its been cold here the last month so its been on the high end
I also have an attached 3 car garage that I heat with gas forced hot air. If I'm spending a lot of time in it, you can add another $100-150 a month to the bill .
Vinny Red '86 944, 05 Ford Super Duty Dually '02 Ram 3500 Diesel 4x4 Dually, '07Jeep Wrangler '62 Mercury Meteor '90 Harley 1200 XL "Live your Life in such a way that the Westboro Baptist Church will want to picket your funeral." |
Upstairs, we've got 2 bedrooms attached to one central room, a small bathroom, and 4 closets. The bathroom and 3 of the 4 closets have small ducts otherwise they get very hot/cold based on outside temps. They have all now been insulated. Now I need to make access doors for all of them to allow access into the attic from the 3 closets. The doors will be insulated. I think we'd need a lot of mini-split units to cover the upstairs and downstairs. And then you're mostly stuck with the big unit up on the wall. Yep, I've heard/read about the new refrigerant which is causing higher costs. Although I've heard that they don't require as much space for the indoor units because the new refrigerants are more efficient or something like that. The good news is that I think our existing unit is 8 SEER, so the difference should be huge if/when we get it replaced.
Small House, around 1,500 sq. feet. Natural Gas heat and water heater. Around $200 for December bill. Up quite a bit from last year. This I'm chalking it up to the Oregon legislature bumping both taxes and regulations, thus increasing costs, to Northwest Natural Gas.
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
3.200 s.f. house w/ one 4 ton and one 3 ton HVAC units. With solar panels, it cost just under $45/mo, for heating and cooling this past year - along with charging an EV.
Marv Evans '69 911E |
You do not have permissi
Meanwhile other things are still happening. Last edited by john70t; 01-10-2025 at 03:49 PM.. |
