987 Boxster oil leak, ideas?
I just ran and got lunch. On the way back, I was running a little fast (about 4k-4.5k rpms). I'd thought things looked a little odd in my rear view a couple of times. When I got home and stopped, I instantly smelled oil smoke and noticed it mostly from the passenger's side. When I look around/through the pass's side rear wheel, I see some oil on the inside of the wheel well and most of the suspension and area under the engine.
So, I seem to have developed a leak on the passenger's side of the car that's dripping down. I "checked" (electronic only) the oil, and it says that it's full. I did have an oil change done not too long ago (<500 miles).
I'm working so I don't have time to crawl under the car.
Old 03-16-2022, 01:08 PM
Deschodt's Avatar
Hopefully it's just something they did at the change, loose oil filter cover or something..
edit: It's been a while since my 987 but I think there is a seal on the plastic casing, betcha it's damaged, old, or as I said not tight enough. fingers crossed for you !
Old 03-16-2022, 01:12 PM
Preferred pronoun:Maestro
Norm K's Avatar
I've never worked on a Boxster, but might the Air Oil Separator be a possible culprit?
_
When in doubt, use overwhelming force.
Old 03-16-2022, 01:16 PM
_
that was my first thought. It seems that usually the smoke from a failed AOS comes from the tailpipe (oil being sucked into the intake), and often results in bad idle and various CEL.
Old 03-16-2022, 01:30 PM
Originally Posted by Deschodt View Post
Hopefully it's just something they did at the change, loose filter cover or something..
Yes, I'm hoping it's something obvious and simple.
Old 03-16-2022, 01:31 PM
Years ago when my Carrera was on jack stands for an extended period, I just finger tightened the oil filter ... than forgot about it.
Backing out months later... I had an Exxon Valdez moment....
It was obvious and simple that....
I wuz stoopid
Old 03-16-2022, 01:40 PM
I did find a post on a site that the AOS can leak at the bellows which is on the passenger's side of the car.
Old 03-16-2022, 02:35 PM
But as mentioned, the bad separated generally causes smoke from the tail pipe most commonly. Spark plug tube seals were a common culprit too.
Old 03-16-2022, 02:55 PM
LWJ LWJ is online now
What about something like the gasket on the filter stuck on the car and now there are two gaskets? Had that happen on a Honda once.
Old 03-16-2022, 02:57 PM
I may have done a hard run the other day (6k rpm in 6th), and had a pretty good puff of smoke the next time that I started the car. But I think that's the only time that I've noticed smoke from the tail pipe.
Can you think of anything on the passenger's side of the engine that would leak after some hard driving?
I haven't done any wrenching on this car since I got it, so I'm unfamiliar with the layout of everything "under the hood".
Old 03-16-2022, 02:59 PM
I'm not sure how likely that is since this isn't a spin-on filter
Old 03-16-2022, 03:00 PM
A930Rocket's Avatar
I wuz stoopid
At least you had a oil filter on. I rebuilt a 69 Mustang and after changing the break in oil, I fired up the car and oil was going everywhere.
I forgot to install the oil filter.
I wuz stoopider
Old 03-16-2022, 05:32 PM
Model Citizen
herr_oberst's Avatar
Forgot to put the oil cap on after an oil change, took a 400 mile trip. Didn't lose much oil, but the oil I lost covered the engine bay in a delightful pattern.
That was pretty stupid.
Old 03-16-2022, 06:00 PM
Recreational Mechanic
Nickshu's Avatar
AOS is at that corner of the engine.
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches
PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing
Old 03-16-2022, 08:47 PM
Again, spark plug tube seals (o rings) were a pretty common oil leak on Boxster and 996.
Old 03-17-2022, 04:46 AM
Thanks folks.
Old 03-17-2022, 07:42 AM
Yup. I just replaced them on my 2002 Boxster S. They were leaking enough to goober up the coil packs, and I started getting a "cylinder 6 misfire" code. This is a pretty easy job, really, at least if you have access to a lift. Wayne's 101 Projects for the Boxster was invaluable.
As an aside, having grown up on air cooled cars, I had some pretty good anxiety about having to learn to work on this thing when I first bought it seven or eight years ago. It's really not bad at all. If you have a lift (which I do not, but several buddies do).
Jeff
'72 911T 3.0 MFI
'93 Ducati 900 Super Sport
Old 03-17-2022, 08:30 AM
David's Avatar
Oil filter housing can be hard to tighten. Was oil change at a porsche shop?
Old 03-17-2022, 09:20 AM
Yep, Einar's garage.
Old 03-17-2022, 12:48 PM
My 996 has been in my garage for over 12 months waiting for me to do the AOS. Every time I get going some other project on our fleet of Land Rovers comes up. Had to do head gaskets on daughter's Disco 2 last summer.
I can certainly empathize. Good Luck!
1969 911E SOLD
2002 996 Cabrio
1995 993 Carrera 4 SOLD
Old 03-17-2022, 01:00 PM
