Two Circuits Sharing Ground Circuit
Electricians -
I have a receptacle circuit in one room that is not grounded (because it is powered by an old lighting circuit - weirdness of 100 y/o house). I've put a GFCI receptacle in first position on that circuit, to get some protection. When I add receptacles to the adjacent room, I'll be able to pull a ground wire from the adjacent room circuit to serve as the ground for this currently ungrounded circuit. I read NEC, it seems to permit two circuits to share the same ground conductor, if the circuits originate in the same enclosure, which these do. So . . . sound ok? |
When it comes to spark-tricity I'm no help at all, but what I can do is share this
http://forums.pelicanparts.com/uploa...1742410657.jpg PS seems to me if you install a combo GFCI/AFCI outlet, you would have all the bases covered. With a grain of salt. |
Is it better to do GFCI/AFCI protection at the breaker or at the receptacle?
A little voice is telling me that I've already over-commented on this subject because of my limited expert-tease.
But what does he know. |
I believe new/current code is that the protection should be at the breaker. I assume that for practical purposes (protection of humans) as long as the GFCI works, it shouldn't matter which position it's in. I don't know about the code-iness of having one ground for 2 circuits. It seems like it should work, and certainly be better than no ground. I'm sure none of that really helps, but I'll be watching to see what the expert consensus is once it arrives. |
GFI's are touchy.
Definitely no shared neutrals. Shared ground should be no big deal. |
I am not an electrician, but I would think that sharing a ground would be ok. In a normal, modern electrical box, all of the circuits use the same ground bar.
I too have an old house that I just acquired. I have noticed that many of my electrical receptacles have a separate ground wire that is attached to a plumbing pipe. This is where the original wiring is knob and tube with no separate ground. I will slowly replace a lot of the wiring with romex as I have access to the main floor electrical from the basement and so this project won't be too difficult. The upstairs will be another issue. |
All the grounds both white and bare are connected at the breaker box, the connection is the central strip between the 2 hot sides and bonded to the box and a rod in the ground
all the hots, black or red, are connected on one side or the other of the braker box |
Also the breaker box and therefore all circuits share the same ground bar. |
Man, GFCI breakers are expensive. CAFCI/GFCI breakers are really expensive. $50-100 a pop. That's like $2,000 just in breakers!
Around here, AFCI breakers will break the piggy bank. I cheat on my rentals. We install AFCI required for breakers throughout house but the kitchen. Just about all are GFCII there. AFter final inspection, out the AFCI and back in with the cheap typical breakers just like all houses had for the past 80 years. Yep, we create solutions to problems we do not have.
I don't know about code up there but it is OK here technically. GFI wouldn't work without a ground. It will trip
Your house shares the same ground throughout. It is not considered a current carrying conductor. The only time it does is during a momentary short. Hopefully the shorted breaker trips open.
The GFCI has to have the dedicated neutral (white) for it to work correctly. Get on line and order the "Ugly"s" electrical references booklet. It is perfect for homeowners that want to safely do some simple electrical troubleshooting around the house. Keeps you out of trouble. It is a small pocket book size. |
I also have an old house with many two prong outlets. Solution when replacing those nasty outlets was a gfi at the first outlet in each room, this protects all the downstream outlets and code says all the 3 prong but groundless outlets need a sticker saying no ground but gfi.
In your case if I understand correctly you’ll be adding a ground wire to the gfi outlet, which I think means that one outlet can now live without the sticker. I’ve read homeowners books about code and I’d put the ground on that gfi but I’d also like to know the answer from an actual expert. There’s some deep knowledge that went into the code and I love learning the whys. |
Or, I’ll power and ground that room’s receptacles from the adjoining room. Here is a table of the different circuit conditions and their risks. http://forums.pelicanparts.com/uploa...1742517732.jpg |
| All times are GMT -8. The time now is 07:53 PM. |
