Born to Lose, Live to Win
ramonesfreak's Avatar
Need storm door that opens in and to left
I have a storm door on my porch that needs to be replaced.
To get into the house via the back porch, you walk up two steps from driveway and open the door with handle on the right and the door opens inwards and to the left.
With a door that opens outward (everything I am seeing online), you would be standing on the steps and not able to open the door safely and likely not up to code
Am I out of luck being able to replace this with the same type door? I can’t find one
Things fall apart; the center cannot hold…
1983 911sc
2025 Chevy Colorado ZR2
Old 04-26-2025, 08:50 AM
Rtrorkt's Avatar
https://www.homedepot.com/p/Andersen-4000-Series-Full-View-Interchangeable-Storm-Door/306553458?51112-Single-Door&29401-36-x-80&29383-White&131044-SmoothControl-Plus&29410-Left-Hand-Outswing&29997-Interchangeable&29394-Clear&31253-Traditional-Nickel&50561-Standard&7202-No&111733-Special-Order
go to homedepot or Lowes or who ever your store is, call up storm doors and there will be options for which hand and swing. Good luck
'86 944T black/red, chip, fuchs 8's and 9's- Sold
'97 Boxster silver/red, big mistake - Sold
'99 C2, silver/black, RoW M030 - sold
"69 912 white w/ '86 3.2L (like the pic, just not the pic)
Old 04-26-2025, 09:52 AM
Right, I can't imagine that having a door swing left or right is an issue, but how would a storm door swing in? RF and I must be talking about 2 separate things. WHen I think "storm door" I think of a second door that is outside of the main door. But you can't have 2 doors that both swing in. One has to swing out while the other swings in.
RF are you just talking about a heavy duty single door, metal clad or something with no windows?
Old 04-26-2025, 10:09 AM
Rtrorkt's Avatar
doors only have two swings, right and left. if it is in-swinging (and agree not sure how that works with a storm door) the install is the same but reversed. And you would need to reverse the hardware. Should not be an issue
Old 04-26-2025, 10:20 AM
When I think of a storm door, I’m thinking of an aluminum and glass door that is installed on the outside of the casing and only opens out.
Unless OP is referring to something else, I can’t see how anything he’s looking for would work.
Old 04-26-2025, 12:14 PM
Rtrorkt's Avatar
an inside door is an inside door whether storm or normal. Hangs the same way
Old 04-26-2025, 02:44 PM
But the storm door which is the ask will only open out.
Old 04-26-2025, 03:15 PM
Kantry Member
oldE's Avatar
I suspect the ask is for an entrance door with an inswing.
Best
Les
Best
Les
Old 04-26-2025, 04:23 PM
From my time in facilities maintenance and ordering doors, I seem to remember 4 different swings: right hand, left hand, right hand reverse and left hand reverse. I wasn’t smart enough to know what one to spec, but I was smart enough to draw a picture and email to my door company.
As pointed out, you wouldn’t be able to push a storm door inward if the regular door was closed, but possibly you just use a storm door only on that entry?
I suspect that because a storm door is almost always used with an inner door and needs to swing out that you are going to have to go custom or possibly modify one.
Rutager West
Old 04-26-2025, 04:37 PM
I think you guys are missing the porch part of RF's request. The storm door he is seeking does not have an entry door right behind it. The way I understand it, you walk up a couple of steps, open a in-swinging door, and now you're on the porch. Take another couple of steps, and you're at the entry door of the house. Hanging a entry door on a porch would look odd. If there are 3 or more steps and no landing, the door must be in-swing.
This site shows what he's looking for - https://www.pcaproducts.com/blog/do-i-need-an-in-swing-screen-door
Old 04-26-2025, 04:38 PM
Easy way to remember. Put your back against the hinge side. If it swings left (toward interior or in-swing), then left hand. Swings right (in-swing), then its a right hand door. If door swings outward, then call it left or right out-swing.
Old 04-26-2025, 04:59 PM
Navin Johnson
TimT's Avatar
I don't know if its a regional thing... Ive been to so many homes, cabins, camps that have stairs going to porch or entrance where the door swings in...
The stair don't have a landing just right up to the door.. so the door swings in.....
Standing on aa top step and swinging a door out is no bueno...
'69 911 GT-5
'75 914 GT-3
and others
Old 04-26-2025, 05:46 PM
A930Rocket's Avatar
This. ^^^
You would need a 36” deep landing to have an outswing door. Even that is awkward.
Old 04-26-2025, 06:45 PM
Thanks for responses
It’s only a metal doors with a glass window held in by clips. The porch was added onto the back of the house probably 30 years ago. The door swings in and to the left
I’ll try to take some pics in a bit
I have learned that it’s called an inswing door but I am having difficulty finding one anywhere. At first I thought maybe they just don’t make these anymore but I can’t imagine e that is true
1983 911sc
Old 04-27-2025, 04:12 AM
Brew Master
cabmandone's Avatar
I'm eager to see the pics. I've never seen an in swing storm door.
Nick
Old 04-27-2025, 04:21 AM
The handle sheered off and fell to the ground. I was going to just replace the handle mechanism but I remember about 5 years trying to replace it because the lock started acting unpredictable but could not locate a replacement. Maybe they are out there and I can just replace rather than the whole door but not sure
---the floor of the porch floor is sinking or sagging, not sure but a gap formed at the base of the door I am guessing from 10 years of the dogs dragging in rain and snow and it staying wet most of the winter
1983 911sc
Old 04-27-2025, 04:29 AM
That’s what I’ve got going on
1983 911sc
Old 04-27-2025, 04:45 AM
Brew Master
cabmandone's Avatar
Looks like a storm door mounted inside rather than out to me. Don't know how much you want to spend but the Larson door with a hidden spring and soft close is nice but it mounts about 1" away from the jamb rather than bring flush (if that makes sense).
Have you searched "in swing storm door handle". Seems like that swing style latch should be easy to find.
https://www.swisco.com/In-swinging-Door-Latch/pd/Replacement-Storm-Door-Handles_Locks/40-028?gad_source=1&gbraid=0AAAAAD_HAIi60H1Bm7laMd-SDaSEGGGwn&gclid=CjwKCAjwq7fABhB2EiwAwk-YbMayJ6Tr9A9-qOH-YuqQkzHx4-bNPQQ9XuroZvoZDN-7aOFdIeHPvRoCKHYQAvD_BwE
Don't know why that amazon link didn't work. Put this in an Amazon search bar "Screen and Storm Door Latch, Non-Keyed, Surface Mount, for Inswinging Doors, Aluminum"
I can't find an actual image of this one but this seems like it would work and has a lock. Brixwell 900-7323
Nick
Old 04-27-2025, 04:51 AM
I’ll check that out thanks
1983 911sc
Old 04-27-2025, 01:49 PM
Ok, based on photos, you just get a door that says "opens out and to the right" and when you mount it inside the porch when standing on the stairs it'll open in and to the left.
Old 04-27-2025, 03:42 PM
