-   -   Inexpensive occasional use bench grinder? (http://forums.pelicanparts.com/off-topic-discussions/1177363-inexpensive-occasional-use-bench-grinder.html)
MBAtarga 05-06-2025 06:11 PM
How far away are you from Richmond or San Antonio?
https://houston.craigslist.org/tls/d/richmond-bench-grinder-inch/7833662219.html
https://sanantonio.craigslist.org/tls/d/san-antonio-lot-of-miscellaneous-tools/7838890620.html
911 Rod 05-07-2025 05:36 AM
My other block.
Yes guys collect them and some have more than 2.
http://forums.pelicanparts.com/uploa...1746625011.jpg
masraum 05-07-2025 11:15 AM
65 miles or 115 miles. I'm generally at least 60 miles from EVERYWHERE.
My place to the westernmost edge of Houston - 55-60 miles
downtown Houston 82 miles
downtown Austin 82 miles
And Houston and it's 'burbs are roughly 50 miles in diameter.
masraum 05-07-2025 11:25 AM
60 miles
http://forums.pelicanparts.com/uploa...1746645703.jpg
60+ miles
The one in Seally is probably only ~50 miles. The rest are somewhere in the 80 - 300 mile range.
http://forums.pelicanparts.com/uploa...1746645733.jpg
cabmandone 05-07-2025 01:03 PM
Rather than buy a bench grinder, why not buy stock in the company that makes the blades for your mower? Seems like they might have a repeat customer which should keep sales going. :D
I think you should buy every bench grinder you can find that seems reasonable, corner the market, then mark them up 10% making the last one free to you.
masraum 05-07-2025 01:12 PM
LOL! I'm using the "level 5" gator blades, I think.
Yep
http://forums.pelicanparts.com/uploa...1746652294.jpg
LOL! That sounds like a plan, corner the market on bench grinders, mark them up since there will be a low supply, and then flood the market at high prices until the price bottoms out. Folks will be using them as door stops by the time I'm done, and I'll be rich!
masraum 05-07-2025 01:14 PM
What I really need
https://static.vegsoc.org/app/upload...-1-708x480.jpg
cabmandone 05-07-2025 01:23 PM
I'd forget about trying to sharpen those with a bench grinder. That downward drop spells doom. That's straight up an angle grinder job IMO.
Tobra 05-07-2025 02:13 PM
You need to hit an estate sale with tools
wdfifteen 05-08-2025 11:42 AM
Originally Posted by Tim Hancock (Post 12459900)
Just c -clamp it to a saw horse or something and do it outside.
Well, I tried it and HELL YES!!!
Thank you. I'll never go back to the grinder again.
It's faster, easier, and does a better job.
It doesn't seem to heat the blade as much, I think because the friction isn't localized like it is on a grinding wheel. It's easy to keep a nice, flat angle, too.
After I did the first one, I got out all my old blades and resurrected them. I had a couple of blades that had big chunks knocked out of them. Used the grinder to square off the edge until I got a straight edge without any missing places, and put a sharp edge on it with the angle grinder.
Thanks for this tip. Another win for PPOT.
http://forums.pelicanparts.com/uploa...1746732809.jpg
masraum 05-08-2025 11:52 AM
You certainly can't argue with those results...
masraum 05-10-2025 11:03 AM
You guys were right. The angle grinder with a flap disc is a VERY quick and easy way to sharpen mower blades!
porsche930dude 05-10-2025 05:01 PM
Its because an angle grinder runs at like 3x the rpm of a bench grinder. I wouldnt suggest buying gator blades. When they get old those fins break off and throw off the balance so you dont get as much life out of them.
